■ General Description The LN2402 is a constant frequency, current mode step-down converter. It is ideal for powering portable equipment that runs from a single cell lithium-Ion (Li+) battery. Switching frequency is internally set at 1.5MHz, allowing the use of small surface mount inductor and capacitors. Automatic PWM/PFM mode operation increases efficiency and decreases output voltage ripple at light loads, further extending battery life. ■ Features High Efficiency: 96% 1.5MHz Constant Switching Frenquency Output Current: 1A Shutdown Current: 《1uA Short Circuit Protection
