在变频器应用的无源混频器
消耗积分:0 | 格式:rar | 大小:0.26 MB | 2017-08-15
分享资料个
  在变频器应用的无源混频器
  而大多数的下变频混频器设计通常使用主动或电流整流的拓扑结构,新的无源混频器电路,可以提供更好的性能比线性显著。
  无源下变频混频器的ltc554x家庭覆盖频率从600 MHz到4 GHz,并提供高转换增益和低噪声系数(NF)具有高线性度。这些混频器的目标是在无线基础设施接收器,需要高增益混频器,以克服高的插入损耗,今天的高选择性,如果SAW滤波器。而传统的无源混频器的变频损耗通常有7分贝,新ltc554x混频器集成中频放大器,如图1所示,产生整体转换增益8分贝。这允许一个额外的15分贝中频滤波器的损失,同时仍然使接收器。
  在变频器应用的无源混频器
  Active versus passive mixers
  Most integrated-circuit mixers are based on an active or current commutating topology. Linear Technology has a wide portfolio of active mixers, such as the LT5527 and LT5557, which are widely accepted due to their ease of use and low power consumption. Nevertheless, their 2 dB to 3 dB of conversion gain is not enough for some wireless infrastructure designs. Furthermore, active mixers typically exhibit higher NF than passive mixers with comparable linearity. LTC554x mixers employ a passive mixer core to achieve the lowest NF with high linearity. Table 1 compares the performance of the LTC5541 passive mixer to the LT5557 active mixer. As shown in the table, the passive mixer has approximately 5 dB higher gain, 2 dB lower NF, and 1.7 dB higher IIP3. The LT5557, however, has much lower DC power consumption.
评论(0)
发评论
下载排行榜
