RS307参数规格书【ASEMI】
消耗积分:0 | 格式:pdf | 大小:77KB | 2017-08-30
赵大只
分享资料个
RS307参数规格书【ASEMI】
  Features
  Ideal for printed circuit board mounting The plastic material used carries Underwriters Laboratory flammability recognition 94V-0 Built-in printed circuit board stand-offs High case dielectric strength High temperature soldering guara
  Mechanical Data Case: Reliable low cost construction utilizing molded plastic technique Terminals: Plated leads solderable per MIL-STD-202, Method 208 Mounting Position: Any Weight: 0.065 ounce, 2.2 grams (approx)
RS307参数规格书【ASEMI】
评论(0)
发评论
下载排行榜
