Diodes Incorporated 集成电路(IC) AP2138N-3.0TRG1
消耗积分:0 | 格式:rar | 大小:0.61 MB | 2017-08-31
分享资料个
  The AP2138/2139 series are CMOS-based positive voltage regulator ICs. Each of these ICs consists of a voltage reference, an error amplifier, a resistor network for setting output voltage and a current limit circuit for current protection. The difference between AP2138 and AP2139 is the AP2139 has an enable circuit with a quick discharge function. These ICs feature high output voltage accuracy, extremely low quiescent current and low dropout voltage which make them ideal for use in various power sources for portable applications. The AP2138/2139 series have 1.2V, 1.4V, 1.5V, 1.8V, 2.1V, 2.2V, 2.5V, 2.8V, 3.0V, 3.3V, 3.6V and 4.0V fixed output voltage versions. The AP2138 series is available in SOT-23-3 and SOT-89 packages, AP2139 series is available in SOT-23-5 package.
  Ultra-low Quiescent Current: 1.0µA Typical  Output Voltages: 1.2V, 1.4V, 1.5V, 1.8V, 2.1V, 2.2V, 2.5V, 2.8V, 3.0V, 3.3V, 3.6V and 4.0V  High Output Voltage Accuracy: ±2%  Output Current: 250mA  Low Dropout Voltage:  25mV Typical at IOUT = 10mA and VOUT = 3V  200mV Typical at IOUT = 100mA and VOUT = 3V  Line Regulation: 6mV Typical  Load Regulation: 25mV Typical  Low Output Voltage Temperature Coefficient: ±100ppm/oC  Low Standby Current: 0.1µA Typical (AP2139)  Active Quick Output Discharge (AP2139)  Logic-controlled Enable (AP2139)  Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)  Halogen and Antimony Free. “Green” Device (Note 3)
评论(0)
发评论
下载排行榜
