The TW8809 is a low cost video format converter that can take either analog CVBS or 24-bit digital RGB format video and output these signals in ITU-R.656 format. The video sources can be scaled and deinterlaced, so that the ITU-R BT.656 output is already formatted to the desired resolution and in progressive format. In addition, the TW8809 has built-in OSD and image enhancement capabilities.
NTSC (M, 4.43) and PAL (B, D, G, H, I, M, N, N combination), PAL (60), SECAM with automatic format detection • Selectable differential or single-ended CVBS input • Supports two differential or 4 single-ended CVBS inputs • 10-bit ADC and analog clamping circuit • Fully programmable static gain or automatic gain control for the Y or CVBS channel • Programmable white peak control for the Y or CVBS channel • High quality adaptive 2D comb filter for both NTSC and PAL inputs • PAL delay line for color phase error correction • Image enhancement with 2D dynamic peaking and CTI • Digital subcarrier PLL for accurate color decoding • Digital horizontal PLL and advanced synchronization processing for VCR playback and weak signal performance • Programmable hue, brightness, saturation, contrast and sharpness
