飞思卡尔半导体技术数据MPC5200B数据表
消耗积分:0 | 格式:rar | 大小:1.24 MB | 2017-09-19
分享资料个
  Key features are shown below. • MPC603e series e300 core – Superscalar architecture – 760 MIPS at 400 MHz (–40 o C to +85 o C) – 16 KB Instruction cache, 16 KB Data cache – Double precision FPU – Instruction and Data MMU – Standard and Critical interrupt capability • SDRAM / DDR Memory Interface – Up to 133 MHz operation – SDRAM and DDR SDRAM support – 256 MB addressing range per CS, two CS available – 32-bit data bus – Built-in initialization and refresh • Flexible multi-function External Bus Interface – Supports interfacing to ROM/Flash/SRAM memories or other memory mapped devices – 8 programmable Chip Selects – Non-multiplexed data access using 8-/16-/32-bit databus with up to 26-bit address – Short or Long Burst capable – Multiplexed data access using 8-/16-/32-bit databus with up to 25-bit address • Peripheral Component Interconnect (PCI) Controller – Version 2.2 PCI compatibility – PCI initiator and target operation – 32-bit PCI Address/Data bus – 33 and 66 MHz operation – PCI arbitration function • ATA Controller – Version 4 ATA compatible external interface—IDE Disk Drive connectivity • BestComm DMA subsystem – Intelligent virtual DMA Controller – Dedicated DMA channels to control peripheral reception and transmission – Local memory (SRAM 16 KB) • 6 Programmable Serial Controllers (PSC) – UART or RS232 interface – CODEC interface for Soft Modem, Master/Slave CODEC Mode, I2S and AC97
评论(0)
发评论
下载排行榜
