The MPC5121e/MPC5123 integrates a high performance e300 CPU core based on the Power Architecture® Technology with a rich set of peripheral functions focused on communications and systems integration. Major features of the MPC5121e/MPC5123 are: • e300 Power Architecture processor core • Power modes include doze, nap, sleep, deep sleep, and hibernate • AXE – Auxiliary Execution Engine • MBX Lite – 2D/3D graphics engine (not available in MPC5123) • DIU – Display interface unit • DDR1, DDR2, and LPDDR/mobile-DDR SDRAM memory controller • MEM – 128 KB on-chip SRAM • USB 2.0 OTG controller with integrated physical layer (PHY) • DMA subsystem • EMB – Flexible multi-function external memory bus interface • NFC – NAND flash controller • LPC – LocalPlus interface • 10/100Base Ethernet • PCI interface, version 2.3 • PATA – Parallel ATA integrated development environment (IDE) controller • SATA – Serial ATA controller with integrated physical layer (PHY) • SDHC – MMC/SD/SDIO card host controller • PSC – Programmable serial controller • I2 C – inter-integrated circuit communication interfaces • S/PDIF – Serial audio interface • CAN – Controller area network • BDLC – J1850 interface • VIU – Video Input, ITU-656 compliant • RTC – On-Chip real-time clock • On-chip temperature sensor • IIM – IC Identification module
