nt3h1101/nt3h1201现场检测引脚和I2C接口产品数据表
消耗积分:0 | 格式:rar | 大小:1.76 MB | 2017-09-26
分享资料个
  NTAG I2C - The entry to the NFC world: simple and lowest cost. The NTAG I2C is the first product of NXP’s NTAG family offering both contactless and contact interfaces (see Figure 1)。 In addition to the passive NFC Forum compliant contactless interface, the IC features an I2C contact interface, which can communicate with a microcontroller if the NTAG I2C is powered from an external power supply. An additional externally powered SRAM mapped into the memory allows a fast data transfer between the RF and I2C interfaces and vice versa, without the write cycle limitations of the EEPROM memory. The NTAG I2C product features a configurable field detection pin, which provides a trigger to an external device depending on the activities at the RF interface. The NTAG I2C product can also supply power to external (low power) devices (e.g. a microcontroller) via the embedded energy harvesting circuitry.
评论(0)
发评论
下载排行榜
