adxl337小型低功耗三轴加速度计
消耗积分:0 | 格式:rar | 大小:0.32 MB | 2017-09-28
分享资料个
  The ADXL337 is a small, thin, low power, complete 3-axis accelerometer with signal conditioned voltage outputs. The product measures acceleration with a minimum full-scale range of ±3 g. It can measure the static acceleration of gravity in tiltsensing applications, as well as dynamic acceleration resulting from motion, shock, or vibration. The user selects the bandwidth of the accelerometer using the CX, CY, and CZ capacitors at the XOUT, YOUT, and ZOUT pins. Bandwidths can be selected to suit the application, with a range of 0.5 Hz to 1600 Hz for X and Y axes and a range of 0.5 Hz to 550 Hz for the Z axis. The ADXL337 is available in a small, low profile, 3 mm × 3 mm × 1.45 mm, 16-lead, lead frame chip scale package (LFCSP_LQ)。
评论(0)
发评论
下载排行榜
