ESD保护的单通道RS-232线路驱动器/接收器adm3101e数据表
消耗积分:0 | 格式:rar | 大小:0.31 MB | 2017-09-29
分享资料个
  The ADM3101E is a high speed, single-channel, RS-232/ ITU-T V.28 transceiver interface device that operates from a single 3.3 V power supply. Low power consumption makes it ideal for battery-powered portable instruments. The ADM3101E conforms to the EIA/TIA-232E and ITU-T V.28 specifications and operates at data rates of up to 460 kbps. All RS-232 (TOUT and RIN) and CMOS (TIN and ROUT) inputs and outputs are protected against electrostatic discharges (up to ±15 kV ESD protection)。 Because of the ±15 kV ESD protection of the ADM3101E input/output pins, this device is ideally suited for operation in electrically harsh environments or where RS-232 cables are frequently plugged and unplugged. Four external 0.1 μF charge pump capacitors are used for the voltage doubler/inverter permitting operation from a single 3.3 V supply. The ADM3101E is available in both a 12-lead LFCSP and 16-lead QSOP, specified over the −40°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
