ad7400a隔离调制器数据表
消耗积分:0 | 格式:rar | 大小:0.37 MB | 2017-09-29
分享资料个
  The AD7400A1 is a second-order, Σ-Δ modulator that converts an analog input signal into a high speed, 1-bit data stream with on-chip digital isolation based on Analog Devices, Inc., iCoupler® technology. The AD7400A operates from a 5 V power supply and accepts a differential input signal of ±250 mV (±320 mV full scale)。 The analog input is sampled continuously by the analog modulator, eliminating the need for external sampleand-hold circuitry. The input information is contained in the output stream as a density of ones with a data rate of 10 MHz. The original information can be reconstructed with an appropriate digital filter. The serial I/O can use a 5 V or a 3 V supply (VDD2)。 The serial interface is digitally isolated. High speed CMOS, combined with monolithic air core transformer technology, means the on-chip isolation provides outstanding performance characteristics superior to alternatives such as optocoupler devices. The part contains an on-chip reference and has an operating temperature range of −40°C to +125°C. The AD7400A is offered in a 16-lead SOIC package.
ad7400a隔离调制器数据表
评论(0)
发评论
下载排行榜
