ad7457低功耗的伪差分100 kSPS的12位ADC在8引脚SOT-23数据表
消耗积分:0 | 格式:rar | 大小:0.33 MB | 2017-09-30
分享资料个
  The AD7457 is a 12-bit, low power, successive approximation (SAR) analog-to-digital converter that features a pseudo differential analog input. This part operates from a single 2.7 V to 5.25 V power supply and features throughput rates of up to 100 kSPS. The part contains a low noise, wide bandwidth, differential track-and-hold (T/H) amplifier that can handle input frequencies in excess of 1 MHz. The reference voltage for the AD7457 is applied externally to the VREF pin and can range from 100 mV to VDD, depending on what suits the application. The conversion process and data acquisition are controlled using CS and the serial clock, allowing the device to interface with microprocessors or DSPs. The SAR architecture of this part ensures that there are no pipeline delays. The AD7457 uses advanced design techniques to achieve very low power dissipation.
评论(0)
发评论
下载排行榜
