飞思卡尔MPC5604B串口发送程序
消耗积分:1 | 格式:zip | 大小:94KB | 2017-09-30
宋兵乙1569
分享资料个
飞思卡尔MPC5604B串口发送程序
  // Readme.txt
  This project stationery is designed to get you up and running
  quickly with CodeWarrior on your MPC5604B_M27V target.
  The wizard has created the following CodeWarrior target(s):
  The targets are set up for the selected CPU and options,
  but can be easily modified.
  * IMPORTANT *
  If your application will run from flash memory, you should
  initialize some additional registers to improve system
  performance. For MPC551x devices, initialize the PFCRP0 and
  PFCRP1 registers; for other devices, initialize the BIUCR.
  Please review the MPC5604B_M27V reference manual to determine
  appropriate values.
  Sample code for the following language(s) is at your disposal:
  Other options may be available:
  // Getting Started
  To build your project, use the menu Project 》 Make or press F7.
  This will build the selected target.
  // Project structure
  The project generated contains various files/groups:
  - readme.txt: this file
  - Sources: folder with the application source code
  - Header Files: all application and runtime header files
  - Startup Code: user customizable startup code
  - Lcf Files: the linker command files for the different build targets.
  - Runtime: the libraries
  // Adding your own code
  Once everything is working as expected, you can begin adding your own code
  to the project. Keep in mind that we provide this as an example of how to
  get up and running quickly with CodeWarrior. There are certainly other
  ways to handle interrupts and set up your linker command file. Feel free
  to modify any of the source files provided.
  // Additional documentation
  Read the online documentation provided. From within the CodeWarrior IDE,
  select Help 》 CodeWarrior Help.
  // Contacting Freescale
  For bug reports, technical questions, and suggestions, please use the
  forms installed in the Release_Notes folder and send them to:
飞思卡尔MPC5604B串口发送程序
评论(0)
发评论
下载排行榜
