16位100kSPS的单端脉冲星ADC引脚ad7683数据表
消耗积分:0 | 格式:rar | 大小:0.45 MB | 2017-09-30
分享资料个
  The AD7683 is a 16-bit, charge redistribution, successive approximation, PulSAR® analog-to-digital converter (ADC) that operates from a single power supply, VDD, between 2.7 V and 5.5 V. It contains a low power, high speed, 16-bit sampling ADC with no missing codes (B grade), an internal conversion clock, and a serial, SPI-compatible interface port. The part also contains a low noise, wide bandwidth, short aperture delay, track-and-hold circuit. On the CS falling edge, it samples an
评论(0)
发评论
下载排行榜
