双不易失性存储器1024位数字电位器ad5235数据表
消耗积分:0 | 格式:rar | 大小:0.81 MB | 2017-10-12
分享资料个
  The AD5235 is a dual-channel, nonvolatile memory,1 digitally controlled potentiometer2 with 1024-step resolution, offering guaranteed maximum low resistor tolerance error of ±8%. The device performs the same electronic adjustment function as a mechanical potentiometer with enhanced resolution, solid state reliability, and superior low temperature coefficient performance. The versatile programming of the AD5235 via an SPI®-compatible serial interface allows 16 modes of operation and adjustment including scratchpad programming, memory storing and restoring, increment/decrement, ±6 dB/step log taper adjustment, wiper setting readback, and extra EEMEM1 for userdefined information such as memory data for other components, look-up table, or system identification information.In the scratchpad programming mode, a specific setting can be programmed directly to the RDAC2 register, which sets the resistance between Terminal W and Terminal A and Terminal W and Terminal B. This setting can be stored into the EEMEM and is restored automatically to the RDAC register during system power-on.
评论(0)
发评论
下载排行榜
