紧凑的30V/±15V的256位数字电位器ad5290数据表
消耗积分:0 | 格式:rar | 大小:0.52 MB | 2017-10-12
分享资料个
  The AD5290 is one of the few high voltage, high performance, and compact digital potentiometers2, 3 in the market at present. This device can be used as a programmable resistor or resistor divider. The AD5290 performs the same electronic adjustment function as mechanical potentiometers, variable resistors, and trimmers, with enhanced resolution, solid-state reliability, and superior temperature stability. With digital rather than manual control, the AD5290 provides layout flexibility and allows closed-loop dynamic controllability. The AD5290 is available in MSOP-10 package and has 10 kΩ, 50 kΩ, and 100 kΩ options. All parts are guaranteed to operate over the −40°C to +125°C extended automotive temperature range.
评论(0)
发评论
下载排行榜
