LaunchPad板上资源解读
消耗积分:0 | 格式:rar | 大小:0.22 MB | 2017-10-12
分享资料个
  The signal lines XIN and XOUT canalso be used as multipurpose I/Os or
  as a digital frequency input.
  8、It should be noted that there are two 0 ohms resistors (R28 and R29)
  that extend the crystal pin leads to the single-in-line break out connector
  (J2)。 In case of oscillator signal distortion hich leads to a fault indication
  at the basic clock module, these resistors can be used to disconnect
  connector J2 from the oscillating lines.
  R28 和 R29 0 欧,可移除以断开与 J2 的连接
  以上从 MSP-EXP430G2 LaunchPad Experimenter Board User‘s
  Guide.pdf (Literature Number: SLAU318)里面摘录,这些我认为比
  较重要的。
LaunchPad板上资源解读
评论(0)
发评论
下载排行榜
