AD7705_7706
消耗积分:0 | 格式:rar | 大小:0.38 MB | 2017-10-17
分享资料个
  The AD7705/AD7706 are complete analog front ends for low
  frequency measurement applications. These 2-/3-channel devices
  can accept low level input signals directly from a transducer and
  produce serial digital output. The devices employ a Σ-Δ
  conversion technique to realize up to 16 bits of no missing codes
  performance. The selected input signal is applied to a
  proprietary, programmable-gain front end based around an
  analog modulator. The modulator output is processed by an onchip digital filter. The first notch of this digital filter can be programmed via an on-chip control register, allowing adjustment of
  the filter cutoff and output update rate.
  The AD7705/AD7706 devices operate from a single 2.7 V to
  3.3 V or 4.75 V to 5.25 V supply. The AD7705 features two fully
  differential analog input channels; the AD7706 features three
  pseudo differential input channels.
  Both devices feature a differential reference input. Input signal
  ranges of 0 mV to 20 mV through 0 V to 2.5 V can be
  incorporated on both devices when operating with a VDD of 5 V
  and a reference of 2.5 V. They can also handle bipolar input
  signal ranges of ±20 mV through ±2.5 V, which are referenced to
  the AIN(−) inputs on the AD7705 and to the COMMON input
  on the AD7706.
AD7705_7706
评论(1)
发评论
llsluoluo33 2018-06-25
0 回复 举报
我司有完全替换AD7705 AD7706 AD7707,精度和可靠性可用于工业级,规格书,免费样品和原厂技术支持 . 刘qq 2208962322 电话微信18503002452 收起回复
下载排行榜
全部1条评论
