Open NAND Flash Interface (ONFI) 3.0-compliant• Multiple-level cell (MLC) technology
• Organization– Page size x8: 17,600 bytes (16,384 + 1216 bytes)– Block size: 512 pages (8192K + 608K bytes)– Plane size: 2 planes x 1024 blocks per plane– Device size: 128Gb: 2048 blocks;256Gb: 4096 blocks;512Gb: 8192 blocks;1Tb: 16,384 blocks• NV-DDR2 I/O performance– Up to NV-DDR2 timing mode 6– Clock rate: 6ns (NV-DDR2)– Read/write throughput per pin: 333 MT/s• NV-DDR I/O performance– Up to NV-DDR timing mode 5– Clock rate: 10ns (NV-DDR)– Read/write throughput per pin: 200 MT/s• Asynchronous I/O performance– Up to asynchronous timing mode 5–tRC/tWC: 20ns (MIN)– Read/write throughput per pin: 50 MT/s• Array performance– Read page: 115µs (MAX)– Program page: 1600µs (TYP)– Erase block: 3ms (TYP)• Operating Voltage Range– VCC: 2.7–3.6V
– VCCQ: 1.7–1.95V
• Command set: ONFI NAND Flash Protocol• Advanced Command Set– Program cache– Read cache sequential– Read cache random– One-time programmable (OTP) mode– Multi-plane commands– Multi-LUN operations– Read Unique ID– Copyback
• First block (block address 00h) is valid when shipped from factory. For minimum required ECC, seeError Management (page 146
