低功耗HART调制解调器ad5700/ad5700-1数据表
消耗积分:0 | 格式:rar | 大小:0.54 MB | 2017-10-18
分享资料个
  The AD5700/AD5700-1 are single-chip solutions, designed and specified to operate as a HART® FSKhalf-duplex modem, complying with the HART physical layer requirements. The AD5700/AD5700-1 integrateall of the necessary filtering, signal detection, modulating, demodulating and signal generation functions, thus requiring fewexternal components. The 0.5% precision internal oscillator on the AD5700-1 greatly reduces the board space requirements, making it ideal for line-powered applications in both master and slave configurations. The maximum supply current consumption is 115µA, making theAD5700/ AD5700-1 an optimal choiceforlowpowerloop-powered applications. Transmit waveforms are phase continuous 1200 Hz and 2200 Hz sinusoids. The AD5700/AD5700-1 containaccurate carrier detect circuitry and use a standard UART interface
评论(0)
发评论
下载排行榜
