30兆赫至6千兆赫射频/中频增益模块adl5611数据表
消耗积分:0 | 格式:rar | 大小:0.51 MB | 2017-10-20
分享资料个
  The ADL5611 is a single-ended RF/IF gain block amplifier that provides broadband operation from 30 MHz to 6 GHz. The ADL5611 provides a low noise figure of 2.1 dB with a very high OIP3 of 40.0 dBm simultaneously, which delivers a high dynamic range. The ADL5611 provides a gain of 22.2 dB that is stable over frequency, temperature, and power supply, and from device to device. The amplifier is offered in the industry-standard SOT-89 package and is internally matched to 50 Ω at the input and output, making the ADL5611 easy to implement in a wide variety of applications. The only external parts required are the input and output ac coupling capacitors, power supply decoupling capacitors, and bias inductor. The ADL5611 has a high ESD rating of ±1.5 kV (Class 1C) and is fully specified for operation across a wide temperature range of −40°C to +105°C. A fully populated RoHS compliant evaluation board is available.
评论(0)
发评论
下载排行榜
