PFM升压型DC/DC变换器me2108系列DC
消耗积分:0 | 格式:pdf | 大小:604KB | 2017-10-21
马钰人
分享资料个
ME2108Series_E10.0
  ME2108 Series is a PFM Step-up DC/DC converter IC with low supply current by CMOS process. High frequency noise that occurs during switching is reduced by using advanced circuit designed, output voltage is programmable in 0.1V steps between 2.0~7.0V and maximum frequency is 180KHz(TYP.)。 A low ripple, high efficiency step-up DC/DC converter can be constructed of ME2108Xxx with only three external components. Also available is a CE(chip enable) function that reduce power dissipation During shut-down mode. ME2108Xxx is suitable for use with battery-powered instruments with low noise and low supply current.
评论(0)
发评论
下载排行榜
