2.5V或3.3V,2:1多路复用器/解复用器总线开关adg3248数据表
消耗积分:0 | 格式:rar | 大小:0.29 MB | 2017-10-24
分享资料个
  The ADG3248 is a 2.5 V or 3.3 V, high performance 2:1 multiplexer/demultiplexer. It is designed on a low voltage CMOS process, which provides low power dissipation yet gives high switching speed and very low on resistance. The low on resistance allows the input to be connected to the output without additional propagation delay or generating additional ground bounce noise.
  Each switch of the ADG3248 conducts equally well in both directions when on. The ADG3248 exhibits break-before-make switching action, preventing momentary shorting when switching channels.
  The ADG3248 is available in a tiny 6-lead SC70 package.
评论(0)
发评论
下载排行榜
