CMOS低电压2Ω的SPST开关SC70封装ADG741/ADG742数据表
消耗积分:0 | 格式:rar | 大小:0.30 MB | 2017-10-24
分享资料个
  The ADG741/ADG742 are monolithic CMOS SPST switches. These switches are designed using an advanced submicron process that provides low power dissipation, yet offers high switching speed, low on resistance, and low leakage currents. In addition, −3 dB bandwidths of greater than 200 MHz can be achieved. The ADG741/ADG742 can operate from a single 1.8 V to 5.5 V supply, making them ideal for use in battery-powered instruments and with Analog Devices’ new generation of DACs and ADCs. As shown in the Functional Block Diagrams, with a logic input of 1 the switch of the ADG741 is closed, while that of the ADG742 is open. Each switch conducts equally well in both directions when on. The ADG741/ADG742 are available in 6-lead and 5-lead SC70 packages.
评论(0)
发评论
下载排行榜
