0.5ΩCMOS 1.65V至3.6伏4通道多路复用器ADG804数据表
消耗积分:0 | 格式:rar | 大小:0.27 MB | 2017-10-24
分享资料个
  The ADG804 is a low voltage 4-channel CMOS multiplexer comprising four single channels. This device offers ultralow on resistance of less than 0.8 Ω over the full temperature range. The digital inputs can handle 1.8 V logic with a 2.7 V to 3.6 V supply. The ADG804 switches one of four inputs to a common output, D, as determined by the 3-bit binary address lines, A0, A1, and EN. A Logic 0 on the EN pin disables the device. The ADG804 has break-before-make switching. The ADG804 is fully specified for 3.3 V, 2.5 V, and 1.8 V supply operation. It is available in a 10-lead MSOP package.
评论(0)
发评论
下载排行榜
