3/5伏CMOS 0.5ΩSPDT开关复用器SC70的ADG849数据表
消耗积分:0 | 格式:rar | 大小:0.23 MB | 2017-10-25
分享资料个
  The ADG849 is a monolithic, CMOS SPDT (single pole, double throw) switch that operates with a supply range of 1.8 V to 5.5 V. It is designed to offer ultralow on-resistance values of typically 0.5 Ω。 This design makes the ADG849 an ideal solution for applications that require minimal distortion through the switch. The ADG849 also has the capability of carrying large amounts of current, typically 600 mA at 5 V operation.
  Each switch of the ADG849 conducts equally well in both directions when on. The device exhibits break-before-make switching action, thus preventing momentary shorting when switching channels.
  The ADG849 is available in a tiny, 6-lead SC70 package, making it the ideal candidate for space-constrained applications.
评论(0)
发评论
下载排行榜
