lcd12864万年历程序
HDL语言及源代码
6人已加入
  lcd12864带中文字库的128X64 是一种具有4 位/8 位并行、2 线或3 线串行多种接口方式,内部含有国标一级、二级简体 中文字库的点阵图形液晶显示模块;其显示分辨率为128×64, 内置8192 个16*16 点汉字,和128 个16*8 点ASCII 字符 集。利用该模块灵活的接口方式和简单、方便的操作指令,可构成全中文人机交互图形界面。可以显示8×4 行16×16 点 阵的汉字。 也可完成图形显示。低电压低功耗是其又一显著特点。
  lcd12864万年历程序
  #include《reg52.H》#include《intrins.h》#include《math.h》
  ////////////////////////////////////////DS18B20#defineucharunsignedchar#defineuintunsignedintsbitDQ=P1^0;
  //定义DS18B20的单总线
  #defineLcd_BusP0
  sbitLCD_RS=P2^7;//数据/命令选择sbitLCD_RW=P2^6;//读写控制sbitLCD_EN=P2^5;//片选信号
  #defineLCD_DATAP0//8bit数据线#defineLOW0#defineHIGH1
  //初始化指令
  #defineCLEAR_SCREEN0x01//清屏指令:清屏且AC值为00H#defineAC_INIT0x02//将AC设置为00H。且游标移到原点位置
  #defineCURSE_ADD0x06//设定游标移到方向及图像整体移动方向(默认游标右移,图像整体不动)
  #defineFUN_MODE0x30//工作模式:8位基本指令集
  #defineDISPLAY_ON0x0c//显示开,显示游标,且游标位置反白#defineDISPLAY_OFF0x08//显示关
  #defineCURSE_DIR0x14//游标向右移动:AC=AC+1
  #defineSET_CG_AC0x40//设置AC,范围为:00H~3FH
  #defineSET_DD_AC0x80
  #defineFUN_MODEK0x36//扩展指令集,8位指令
  #defineX1address0x80//上半屏X轴起始地址
  #defineX2address0x88//下半屏X轴起始地址
  #defineYaddress0x80//Y轴起始地址
  #defineSet_Column0x40#defineSet_Page0xB8
  ucharcodeshu[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
  ucharcodexingqi[]=“星期”;
  ucharcodehanzishu[]=“一二三四五六日”;unsignedcharTempData=0;doubleDS18B20Data;uintjiemian=0;
  //////////////////////////////////////////DS1302sbitDS1302_RST=P1^4;sbitDS1302_IO=P1^3;sbitDS1302_SCK=P1^2;
  unsignedchartable[]={0X00,0X18,0X0c,0X15,0X06,0X01,0X0a};//0s24min12hour14ri5yue5zhou2010nianunsignedchardatatable1[7];
  //ucharcodetable2[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};ucharcodeshuzi[]={
  0x00,
  0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f,0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,0x2f,0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,};
  unsignedcharaa,bb;
  ucharmiaoge,miaoshi,fenge,fenshi,shige,shishi,rige,rishi,yuege,yueshi,zhou,niange,nianshi;
  ucharshezhinum=0;
  //unsignedcharshi,ge;
  ////////////////////////////////////////////////键盘扫描
  sbitkey_mnue=P3^7;
  sbitkey_jia=P2^0;
  sbitkey_jian=P2^1;
  sbitkey_enter=P2^2;
  ucharkey_number=0;
  //intnian,yue,ri,shi,fen;
  /////////////////////////////////////////////////红外
  sbitHW_IRQ=P3^2;//定义38KHz一体化红外接收头与
  CPU的连接unsignedchar
  DT;
  staticunsignedchardataIRCode[3],IRCON,IRCON2;
  //////////////////////////////////////////////////蜂鸣器sbitBEEP=P1^1;
  *函数名称:DS18B20_Delay()
  *功能:DS18B20软件延时专用
  *入口参数:count延时参数,值越大,延时越长
  *出口参数:无
  voidDS18B20_Delay(uintcount)//延时函数{
  while(count--);}
  *函数名称:DS18B20_Init()*功能:DS18B20初始化*入口参数:无
  *出口参数:返回值为1则初始化成功*返回值为0则初始化失败
  ucharDS18B20_Init(void){
  ucharx=0;
  DQ=1;
  //DQ复位DS18B20_Delay(8);
  //稍做延时
  DQ=0;
  //单片机将DQ拉低DS18B20_Delay(80);//精确延时,大于480usDQ=1;
  //拉高总线DS18B20_Delay(14);//稍做延时后
  x=DQ;//若x=0则初始化成功,若x=1则
  初始化失败
  DS18B20_Delay(20);
  return(~x);}
  *函数名称:DS18B20_Read1Byte()*功能:从DS18B20读一个字节*入口参数:无
  *出口参数:从DS18B20读出的一个字节
  ucharDS18B20_Read1Byte(void){
  uchari=0;uchardat=0;for(i=8;i》0;i--){
  DQ=0;//给脉冲信号dat》》=1;DQ=1;
  //给脉冲信号
  if(DQ)dat|=0x80;DS18B20_Delay(4);}
  return(dat);}
  *函数名称:DS18B20_Write1Byte()
  *功能:向DS18B20写一个字节
  *入口参数:dat要写入DS18B20的一字节数据
  *出口参数:无
  voidDS18B20_Write1Byte(uchardat){
  uchari=0;
  for(i=8;i》0;i--){
  DQ=0;
  DQ=dat&0x01;DS18B20_Delay(5);
  DQ=1;dat》》=1;}}
  *函数名称:Read_Disp_Temperature()*功能:读取并显示温度*入口参数:无*出口参数:无
  doubleRead_Disp_Temperature(void){
  uinta=0,b=0,c=0,d=0,e=0,t=0;doublett=0;
  DS18B20_Init();
  DS18B20_Write1Byte(0xCC);//跳过读序号列号的操作
  DS18B20_Write1Byte(0x44);//启动温度转换
  DS18B20_Init();
  DS18B20_Write1Byte(0xBE);//读取温度寄存器
  a=DS18B20_Read1Byte();
  b=DS18B20_Read1Byte();
  t=b;
  t《《=8
  t=t|a;
  //tt=t*0.0625;
  returnt;
  //*****************************************************************//函数名称:delay(uintt)延时函数。对于12M晶振大约延时1ms//入口参数:t//出口参数:无
  //*****************************************************************voiddelay(uintt){
  uinti;while(t--){
  for(i=0;i《125;i++);}}
  ////////////////////////////////////////////////////////////////蜂鸣器鸣叫voidFM(){
  BEEP=0;delay(100);BEEP=1;}
  //*****************************************************************//函数名称:write_cmd(uintlcd_cmd)写指令//入口参数:lcd_cmd//返回参数:无
  //*****************************************************************voidWriteCmd12864(ucharlcd_cmd){
  LCD_RS=LOW;LCD_RW=LOW;LCD_EN=HIGH;
  LCD_DATA=lcd_cmd;LCD_EN=LOW;}
  //函数名称:write_data(uintlcd_data)写数据
  //入口参数:current_data
  //返回参数:无
  voidWriteData12864(ucharlcd_data)
  LCD_RS=HIGH;
  LCD_RW=LOW;
  LCD_EN=HIGH;
  LCD_DATA=lcd_data;
  LCD_EN=LOW;}
  函数名称:Write12864(uint)写数据
  入口参数:cmd,data
  返回参数:无
  voidWrite12864(ucharlcd_cmd,ucharlcd_data)
  WriteCmd12864(lcd_cmd);
  WriteData12864(lcd_data);
  //函数名称:ReadBusy()判忙
  //入口参数:无
  //返回参数:
  “1”忙;
  “0”不忙
  voidReadBusy(void)
  uchari=5;
  while(i--);}
  函数名称:LcdInit()初始化
  入口参数:无
  返回参数:无
  voidLcdInit()
  delay(50);
  WriteCmd12864(FUN_MODE);delay(1);
  //WriteCmd12864(FUN_MODE);//delay(1);
  WriteCmd12864(DISPLAY_ON);delay(1);
  //WriteCmd12864(AC_INIT);//delay(1);
  WriteCmd12864(CLEAR_SCREEN);delay(20);
  WriteCmd12864(CURSE_ADD);delay(1);}
  函数名称:LcdClear()清屏
  入口参数:无
  返回参数:无
  ****************************************************************/voidLcdClear(void){
  ReadBusy();
  WriteCmd12864(CLEAR_SCREEN);delay(3);}
  voidwrite_date(uchardate){
  LCD_RS=1;
  LCD_RW=0;
  LCD_EN=0;
  P0=date;delay(5);
  LCD_EN=1;delay(5);
  LCD_EN=0;
  voidinput1byte(unsignedchardate)
  unsignedchari;for(i=0;i《8;i++)
  DS1302_IO=date&0x01;DS1302_SCK=0;DS1302_SCK=1;date》》=1;}}
  unsignedcharread1byte(){
  unsignedchari,date=0;for(i=0;i《8;i++){
  date》》=1;
  DS1302_SCK=1;DS1302_SCK=0;DS1302_IO=1;
  if(DS1302_IO)date=date|0x80;}
  returndate;}
  voidwrite1302(unsignedcharaddress,unsignedchardate){
  DS1302_RST=0;DS1302_SCK=0;DS1302_RST=1;input1byte(address);input1byte(date);DS1302_RST=0;DS1302_SCK=1;}
  unsignedcharread1302(unsignedcharaddress){
  unsignedcharucdat;
  DS1302_RST=0;
  DS1302_SCK=0;
  DS1302_RST=1;
  ucdat=read1byte();
  DS1302_RST=0;
  DS1302_SCK=1;
  returnucdat;
  voidset1302(unsignedcharaddress,unsignedchartable[],unsignedcharn){
  unsignedchari;
  write1302(0x8e,0x00);for(i=0;i《n;i++){
  write1302(address,table[i]);address+=2;}
  write1302(0x8e,0x80);}
  voidread1302xulie(unsignedcharaddress,unsignedcharn){
  unsignedchari;for(i=0;i《n;i++){
  table1[i]=read1302(address);address+=2;}}
  voidinit1302(){
  write1302(0x8e,0x00);//取消写保护
  write1302(0x90,0x00);//清零涓流充电寄存器
  voidchuli()
  unsignedcharaa,bb,i;
  for(i=0;i《7;i++)
  aa=table[i]/10;
  bb=table[i]%10;
  table[i]=(aa《《4)|bb;
  voidchuli2(unsignedcharz){
  aa=table1[z]&0x0f;
  //年
  bb=(table1[z]&0xf0)》》4;table1[z]=bb*10+aa;}
  voidjiashijian(){
  switch(key_number)
  case0:break;case1:table1[6]++;
  //if(table1[6]==10)table1[6]=5;
  write1302(0x8c,table[6]);
  write1302(0x8e,0x80);_nop_();
  _nop_();break;
  case2:table1[4]++;
  if(table1[4]==13)table1[4]=1;
  write1302(0x88,table1[4]);
  _nop_();
  _nop_();
  break;
  case3:table1[3]++;
  if(table1[3]==31)table1[3]=1;
  write1302(0x86,table1[3]);
  _nop_();
  _nop_();
  break;
  case4:table1[5]++;
  if(table1[5]==8)table1[5]=1;
  write1302(0x8a,table1[5]);
  _nop_();
  _nop_();
  break;
  case5:table1[2]++;
  if(table1[2]==24)table1[2]=0;
  write1302(0x84,table1[2]);
  _nop_();
  _nop_();
  break;case6:
  table1[1]++;
  if(table1[1]==61)table1[1]=0;
  write1302(0x82,table1[1]);
  table1[0]=0;
  write1302(0x80,0);
  _nop_();
  _nop_();
  break;
  voidjianshijian(){
  switch(key_number)
  case0:break;case1:table1[6]--;
  if(table1[6]》99)table1[6]=99;
  write1302(0x8c,table1[6]);
  _nop_();
  _nop_();
  break;
  case2:table1[4]--;
  if(table1[4]==0)table1[4]=12;
  _nop_();
  break;
  case3:table1[3]--;
  if(table1[3]==0)table1[3]=31;
  _nop_();
  _nop_();
  break;
  case4:table1[5]--;
  if(table1[5]==0)table1[5]=7;
  write1302(0x8a,table1[5]);write1302(0x8e,0x80);_nop_();_nop_();break;case5:
  table1[2]--;
  if(table1[2]==-1)table1[2]=0;write1302(0x8e,0x00);write1302(0x84,table1[2]);write1302(0x8e,0x80);_nop_();
  _nop_();break;case6:
  table1[1]--;
  if(table1[1]》60)table1[1]=60;write1302(0x8e,0x00);write1302(0x82,table1[1]);table1[0]=0;
  write1302(0x80,0);write1302(0x8e,0x80);_nop_();
  _nop_();break;
  }keyscan(){
  if(key_mnue==0){
  delay(10);
  if(key_mnue==0){FM();
  key_number++;}
  if(key_number==7)
  {FM();
  key_number=1;}}
  while(!key_mnue);if(key_jia==0){
  delay(10);if(key_jia==0){
  FM();
  jiashijian();}}
  while(!key_jia);if(key_jian==0){
  delay(10);
  if(key_jian==0){
  FM();
  jianshijian();}
  while(!key_jian);if(key_enter==0){
  delay(10);
  if(key_enter==0){FM();
  key_number=0;}}
  while(!key_enter);
  jiemian++;
  if(jiemian==15){
  ReadBusy();jiemian=0;
  switch(key_number)//调时间时界面显示{
  //case0:WriteCmd12864(0x08);
  break;case1:WriteCmd12864(0x83);
  ReadBusy();
  WriteData12864(0x5f);ReadBusy();
  WriteData12864(0x5f);break;
  case2:WriteCmd12864(0x84);
  ReadBusy();
  case3:WriteCmd12864(0x85);
  ReadBusy();
  case4:WriteCmd12864(0x95);
  ReadBusy();
  case5:WriteCmd12864(0x8a);
  ReadBusy();
  case6:WriteCmd12864(0x8b);
  ReadBusy();
  WriteData12864(0x3a);ReadBusy();
  WriteData12864(0x5f);break;}}}
  voidmain(void){
  uinta=0,b=0,c=0,t=0,tt;ucharerhang=0;
  TMOD=0x01;
  //定时器0方式1
  EA=1;//允许CPU中断IT0=1;
  //INT0下降沿有效EX0=1;
  //开INT0中断
  init1302();//chuli();
  //set1302(0x80,table,7);
  LcdClear();
  while(1){
  LcdInit();
  //液晶初始化
  LcdClear();
  delay(100);
  LcdClear();
  ReadBusy();
  while(1){
  tt=Read_Disp_Temperature();
  DS18B20Data=tt*0.0625;
  t=DS18B20Data*10+0.5;
  //放大10倍
  输出并四舍五入
  a=t/100;
  //十位b=t/10-a*10;//个位//DS_20[1]=0x24;c=t-a*100-b*10;//小数位
  read1302xulie(0x81,7);
  chuli2(0);
  //miaomiaoshi=table1[0]/10;
  miaoge=table1[0]%10;
  chuli2(1);
  //minfenshi=table1[1]/10;
  fenge=table1[1]%10;
  chuli2(2);
  //hourshishi=table1[2]/10;
  shige=table1[2]%10;
  chuli2(3);
  //ririshi=table1[3]/10;
  rige=table1[3]%10;
  chuli2(4);
  //yueyueshi=table1[4]/10;
  yuege=table1[4]%10;
  chuli2(5);
  //xingqi
  zhou=table1[5];
  chuli2(6);
  //年nianshi=table1[6]/10;
  niange=table1[6]%10;
  ReadBusy();
  WriteCmd12864(0x9b);
  //第四行显示ReadBusy();
  WriteData12864(shu[a]);
  ReadBusy();
  WriteData12864(shu[b]);
  //WriteCmd12864(0x9d);
  ReadBusy();
  WriteData12864(0x2e);
  ReadBusy();
  WriteData12864(shu[c]);
  ReadBusy();
  //WriteCmd12864(0x9e);
  ReadBusy();
  WriteData12864(0x60);
  ReadBusy();
  WriteData12864(0x43);
  ReadBusy();
  keyscan();
  ReadBusy();
  WriteCmd12864(0x92);
  //第二行显示
  ReadBusy();
  for(erhang=0;
  erhang《4;erhang++)
  write_date(xingqi[erhang]);
  ReadBusy();
  ReadBusy();
  for(erhang=0;erhang《2;
  erhang++)
  write_date(hanzishu[erhang+zhou*2-2]);
  ReadBusy();}
  ReadBusy();
  keyscan();
  ReadBusy();
  WriteCmd12864(0x82);
  //第一行显示ReadBusy();
  WriteData12864(shu[2]);
  ReadBusy();
  WriteData12864(shu[0]);
  ReadBusy();
  WriteData12864(shu[nianshi]);
  ReadBusy();
  WriteData12864(shu[niange]);
  ReadBusy();
  WriteData12864(shu[yueshi]);
  ReadBusy();
  WriteData12864(shu[yuege]);
  ReadBusy();
  ReadBusy();
  WriteData12864(shu[rishi]);
  ReadBusy();
  WriteData12864(shu[rige]);
  ReadBusy();
  keyscan();
  ReadBusy();
  第19页共19页
  //第三行显示ReadBusy();
  WriteData12864(shu[shishi]);
  ReadBusy();
  WriteData12864(shu[shige]);
  ReadBusy();
  ReadBusy();
  WriteData12864(shu[fenshi]);
  ReadBusy();
  ReadBusy();
  WriteData12864(shu[fenge]);
  ReadBusy();
  ReadBusy();
  WriteData12864(shu[miaoshi]);
  ReadBusy();
  ReadBusy();
  WriteData12864(shu[miaoge]);
  ReadBusy();
  ReadBusy();
  keyscan();
  ReadBusy();
  ReadBusy();
