lcd19264驱动程序
HDL语言及源代码
6人已加入
  19264,是液晶模组的分辨率,也就是有192*64个点,是点阵液晶。液晶模组的亮度可能会由于CCFL引线对金属壳的耦合分流而受到影响。逆变器的设计应该充分考虑这部分的漏电。有必要全面评估液晶模组和逆变器安装在主机设备中的情况,确保达到亮度要求。
  lcd19264驱动程序
  #include “Public.h”
  #define Fisrt 01
  #define Second 02
  #define Third 03
  /*定义LCD控制端口*/
  sbit LCD_RS = P0^7;
  sbit LCD_RW = P0^6;
  sbit LCD_CE = P0^5;
  sbit LCD_CSA = P0^4;
  sbit LCD_REST = P0^3;
  sbit LCD_CSB = P0^2;
  sbit LCD_CSC = P0^1;
  #define DATA_BUS P2
  函数功能说明:判断LCD忙函数
  1、
  2、
  3、
  void Read_busy(unsigned char Area)
  unsigned char temp = 0;
  do
  LCD_CE = 0;
  LCD_RW = 1;
  LCD_RS = 0;
  switch(Area)
  case Fisrt:
  LCD_CSA = 0;
  break;
  case Second:
  LCD_CSB = 0;
  break; case Third:
  LCD_CSC = 0;
  break; default:break;
  _nop_();
  LCD_CE = 1;
  _nop_();
  temp = DATA_BUS;
  LCD_CE = 0;
  LCD_RW = 0;
  switch(Area)
  case Fisrt:
  LCD_CSA = 1;
  break;
  case Second:
  LCD_CSB = 1;
  break; case Third:
  LCD_CSC = 1;
  break;
  default:break;
  LCD_CE = 1;
  }while(temp&0x80);
  函数功能说明: 设置坐标
  1、 液晶分为三个区 A、B、C
  2、 设置每个区的坐标
  3、 送坐标到总线上
  void Set_Locatexy(unsigned char x_add,unsigned char y_add)
  switch(x_add&0xc0)
  case 0x00:
  Write_command(Fisrt,x_add&0x3f)
  break;
  case 0x40:
  break;
  case 0x80:
  break;
  default:break;
  函数功能说明: 写数据
  1、 液晶分为三个区 A、B、C
  2、 设置每个区的片选信号
  3、 送数据到总线上
  void Write_data(unsigned char Area_Num,unsigned char Lcd_data)
  Read_busy(Area_Num);
  LCD_CE = 0;
  /*写入到LCM*/
  LCD_RW = 0;
  LCD_RS = 1; //数据
  switch(Area_Num)
  case Fisrt:
  LCD_CSA = 0;
  break;
  case Second:
  LCD_CSB = 0;
  break; case Third:
  LCD_CSC = 0;
  break;
  default:break;
  _nop_();
  LCD_CE = 1;
  _nop_();
  DATA_BUS = Lcd_data;
  _nop_();
  _nop_();
  LCD_CE = 0;
  LCD_RW = 1;
  switch(Area_Num)
  case Fisrt:
  LCD_CSA = 1;
  break;
  case Second:
  LCD_CSB = 1;
  break;
  case Third:
  LCD_CSC = 1;
  break;
  default:break;
  LCD_CE = 1;
  函数功能说明: 写命令
  1、 液晶分为三个区 A、B、C
  2、 设置每个区的片选信号
  3、 送命令到总线上
  void Write_command(unsigned char Area_Num,unsigned char Lcd_Command)
  LCD_CE = 0; /*写入到LCM*/
  LCD_RW = 0;
  LCD_RS = 0; //指 令
  switch(Area_Num)
  case Fisrt:
  LCD_CSA = 0;
  break;
  case Second:
  LCD_CSB = 0;
  break;
  case Third:
  LCD_CSC = 0;
  break;
  default:break;
  _nop_();
  LCD_CE = 1;
  _nop_();
  DATA_BUS = Lcd_Command;
  _nop_();
  _nop_();
  LCD_CE = 0;
  LCD_RW = 1;
  switch(Area_Num)
  case Fisrt:
  LCD_CSA = 1;
  break;
  case Second:
  LCD_CSB = 1;
  break;
  case Third:
  LCD_CSC = 1;
  break;
  default:break;
  } LCD_CE = 1;
  void Lcminit( void )
  LCD_REST = 0;
  _nop_();
  LCD_REST = 1;
  Write_command(Fisrt,0x40);
  Write_command(Second,0x40);
  Write_command(Third,0x40);
  Write_command(Fisrt,0xb8);
  Write_command(Second,0xb8);
  Write_command(Third,0xb8);
  Write_command(Fisrt,0xc0);
  Write_command(Second,0xc0);
  Write_command(Third,0xc0);
  Write_command(Fisrt,0x3f);
  Write_command(Second,0x3f);
  Write_command(Third,0x3f);
