DS18B20数字温度传感器资料
消耗积分:1 | 格式:rar | 大小:0.6 MB | 2017-12-02
分享资料个
  FEATURES
  Unique 1-Wire interface requires only one port pin for communication
  Multidrop capability simplifies distributed temperature sensing applications
  Requires no external components
  Can be powered from data line. Power supply range is 3.0V to 5.5V
  Zero standby power required
  Measures temperatures from -55°C to +125°C. Fahrenheit equivalent is -67°F to +257°F
  ± 0.5° C accuracy from -10°C to +85°C
  Thermometer resolution is programmable from 9 to 12 bits
  Converts 12-bit temperature to digital word in 750 ms (max.)
  User-definable, nonvolatile temperature alarm settings
  Alarm search command identifies and addresses devices whose temperature is outside of programmed limits (temperature alarm condition)
  Applications include thermostatic controls, industrial systems, consumer products, thermometers, or any thermally sensitive system
DS18B20数字温度传感器资料
评论(0)
发评论
下载排行榜
