AD9850产生扫频波的程序
消耗积分:0 | 格式:pdf | 大小:350KB | 2017-12-06
夜默z
分享资料个
对学习很有帮助
  AD9850产生扫频波的程序 2的32次方等于 4294967296 控制字的计算: fOUT = (Δ Phase × CLKIN)/4294967296 where: Δ Phase is the value of the 32­bit tuning word. CLKIN is the input reference clock frequency in MHz. fOUT is the frequency of the output signal in MHz. DATA=FOUT/CLK*4294967296 10k­­200khz 频率控制字如下步进10K 00418937,0083126F,00C49BA6,010624DD,0147AE14 0189374C,01CAC083,020C49BA,024DD2F2,028F5C29, 02D0E560,03126E98,0353F7CF,03958106,03D70A3D 04189375,045A1CAC,049BA5E3,04DD2F1B,051EB852 uchar code saopin[21][5]= { 0X00,0X00,0X00,0XA7,0XC6, //100HZ 0X00,0X00,0X41,0X89,0X37, //10K 0X00,0X00,0X83,0X12,0X6F, 0X00,0X00,0XC4,0X9B,0XA6, 0X00,0X01,0X06,0X24,0XDD, 0X00,0X01,0X47,0XAE,0X14, 0X00,0X01,0X89,0X37,0X4C, //60K 0X00,0X01,0XCA,0XC0,0X83, 0X00,0X02,0X0C,0X49,0XBA, 0X00,0X02,0X4D,0XD2,0XF2, 0X00,0X02,0X8F,0X5C,0X29, 0X00,0X02,0XD0,0XE5,0X60, //110K 0X00,0X03,0X12,0X6E,0X98,
评论(0)
发评论
下载排行榜
