ADL5504,pdf daasheet(450 MHz t
消耗积分:0 | 格式:rar | 大小:232 | 2009-12-21
分享资料个
The ADL5504 is a TruPwr™ mean-responding (true rms) power detector for use in high frequency receiver and transmitter signal chains from 450 MHz to 6000 MHz. Requiring only a single supply between 2.5 V and 3.3 V, the detector draws less than 1.8 mA. The input is internally ac-coupled and has a nominal input impedance of 500 Ω. The rms output is a linear-responding dc voltage with a conversion gain of 1.87 V/V rms at 900 MHz.
评论(0)
发评论
下载排行榜
