SOT-23塑料封装晶体管S8550
消耗积分:1 | 格式:rar | 大小:0.6 MB | 2017-12-07
分享资料个
    SOT-23
  S8550  TRANSISTOR (PNP)
FEATURES 1. BASE
z Complimentary to S8050 2. EMITTER
z Collector current: IC=0.5A 3. COLLECTOR
MARKING : 2TY
MAXIMUM RATINGS (Ta=25 unless otherwise noted)
  Symbol Parameter Value Unit
  VCBO Collector-Base Voltage -40 V
  VCEO Collector-Emitter Voltage -25 V
  VEBO Emitter-Base Voltage -5 V
  IC Collector Current -Continuous -0.5 A
  PC Collector Power Dissipation 0.3 W
  Tj Junction Temperature 150
  Tstg Storage Temperature -55-150
ELECTRICAL CHARACTERISTICS (Ta=25 unless otherwise specified)
Parameter   Symbol Test conditions   Min Max Unit
Collector-base breakdown voltage   V(BR)CBO IC = -100μA, IE=0   -40   V
Collector-emitter breakdown voltage   V(BR)CEO IC =-1mA, IB=0   -25   V
Emitter-base breakdown voltage   V(BR)EBO IE= -100μA, IC=0   -5   V
Collector cut-off current   ICBO VCB= -40V, IE=0     -0.1 μA
Collector cut-off current   ICEO VCE= -20V, IB=0     -0.1 μA
Emitter cut-off current   IEBO VEB= -3V, IC=0     -0.1 μA
      hFE(1) VCE= -1V, IC= -50mA   120 400
DC current gain
  hFE(2) VCE= -1V, IC= -500mA   50
Collector-emitter saturation voltage   VCE(sat) IC=-500mA, IB= -50mA     -0.6 V
Base-emitter saturation voltage   VBE(sat) IC=-500mA, IB= -50mA     -1.2 V
Transition frequency   fT VCE= -6V, IC= -20mA   150   MHz
  f=30MHz
CLASSIFICATION OF hFE(1)
Rank   L   H
Range   120-200     200-350
SOT-23塑料封装晶体管S8550
评论(0)
发评论
下载排行榜
