宽输入范围电流模式升压控制器
消耗积分:1 | 格式:rar | 大小:0.5 MB | 2017-12-12
分享资料个
  TPS4021x 4.5-V to 52-V Input Current Mode Boost Controller
1 Features 3  Description
For Boost, Flyback, SEPIC, LED Drive Apps The TPS40210 and TPS40211 are wide-input voltage
•  Wide Input Operating Voltage: 4.5 V to 52 V (4.5 V to 52 V), nonsynchronous boost controllers.
They  are  suitable  for  topologies  which  require  a
Adjustable Oscillator Frequency
grounded  source  N-channel  FET  including  boost,
Fixed Frequency Current Mode Control flyback, SEPIC and various LED Driver applications.
Internal Slope Compensation The device features include programmable soft-start,
overcurrent  protection  with  automatic  retry  and
Integrated Low-Side Driver
programmable  oscillator  frequency.  Current  mode
Programmable Closed-Loop Soft-Start control  provides  improved  transient  response  and
Overcurrent Protection simplified loop compensation. The main difference
between the two parts is the reference voltage to
External Synchronization Capable
which the error amplifier regulates the FB pin.
  (TPS40211)   Device Information(1)
Low Current Disable Function PART NUMBER   PACKAGE BODY SIZE (NOM)
Create a Custom Design Using the TPS4021x TPS40210   HVSSOP (10) 3.05 mm x 4.98 mm
  with the WEBENCH Power Designer TPS40211   VSON (10) 3.10 mm x 3.10 mm
2 Applications (1) For all available packages, see the orderable addendum at
the end of the datasheet.
LED Lighting
Industrial Control Systems
Battery Powered Systems
评论(0)
发评论
下载排行榜
