nrf24l01收发程序详解
RF/无线
1771人已加入
  nRF24L01驱动程序分享
  nRF24L01的发送程序:
  #include 《reg51.h》
  #define uchar unsigned char
  #define uint unsigned int
  sbit CE = P1^0; // Chip Enable pin signal (output)
  sbit CSN = P1^1; // Slave Select pin, (output to CSN, nRF24L01)
  sbit IRQ = P1^5; // Interrupt signal, from nRF24L01 (input)
  sbit MISO = P1^4; // Master In, Slave Out pin (input)
  sbit MOSI = P1^3; // Serial Clock pin, (output)
  sbit SCK = P1^2; // Master Out, Slave In pin (output)
  // SPI(nRF24L01) commands
  #define READ_REG 0x00 // Define read command to register
  #define WRITE_REG 0x20 // Define write command to register
  #define RD_RX_PLOAD 0x61 // Define RX payload register address
  #define WR_TX_PLOAD 0xA0 // Define TX payload register address
  #define FLUSH_TX 0xE1 // Define flush TX register command
  #define FLUSH_RX 0xE2 // Define flush RX register command
  #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
  #define NOP 0xFF // Define No Operation, might be used to read status register
  // SPI(nRF24L01) registers(addresses)
  #define CONFIG 0x00 // ‘Config’ register address
  #define EN_AA 0x01 // ‘Enable Auto Acknowledgment’ register address
  #define EN_RXADDR 0x02 // ‘Enabled RX addresses’ register address
  #define SETUP_AW 0x03 // ‘Setup address width’ register address
  #define SETUP_RETR 0x04 // ‘Setup Auto. Retrans’ register address
  #define RF_CH 0x05 // ‘RF channel’ register address
  #define RF_SETUP 0x06 // ‘RF setup’ register address
  #define STATUS 0x07 // ‘Status’ register address
  #define OBSERVE_TX 0x08 // ‘Observe TX’ register address
  #define CD 0x09 // ‘Carrier Detect’ register address
  #define RX_ADDR_P0 0x0A // ‘RX address pipe0’ register address
  #define RX_ADDR_P1 0x0B // ‘RX address pipe1’ register address
  #define RX_ADDR_P2 0x0C // ‘RX address pipe2’ register address
  #define RX_ADDR_P3 0x0D // ‘RX address pipe3’ register address
  #define RX_ADDR_P4 0x0E // ‘RX address pipe4’ register address
  #define RX_ADDR_P5 0x0F // ‘RX address pipe5’ register address
  #define TX_ADDR 0x10 // ‘TX address’ register address
  #define RX_PW_P0 0x11 // ‘RX payload width, pipe0’ register address
  #define RX_PW_P1 0x12 // ‘RX payload width, pipe1’ register address
  #define RX_PW_P2 0x13 // ‘RX payload width, pipe2’ register address
  #define RX_PW_P3 0x14 // ‘RX payload width, pipe3’ register address
  #define RX_PW_P4 0x15 // ‘RX payload width, pipe4’ register address
  #define RX_PW_P5 0x16 // ‘RX payload width, pipe5’ register address
  #define FIFO_STATUS 0x17 // ‘FIFO Status Register’ register address
  #define TX_ADR_WIDTH 5 // 5字节宽度的发送/接收地址
  #define TX_PLOAD_WIDTH 4 // 数据通道有效数据宽度
  uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // 定义一个静态发送地址
  uchar RX_BUF[TX_PLOAD_WIDTH];
  uchar TX_BUF[TX_PLOAD_WIDTH];
  uchar flag;
  uchar DATA = 0x01;
  uchar bdata sta;
  sbit RX_DR = sta^6;
  sbit TX_DS = sta^5;
  sbit MAX_RT = sta^4;
  void init_io(void)
  CE = 0; // 待机
  CSN = 1; // SPI禁止
  SCK = 0; // SPI时钟置低
  IRQ = 1; // 中断复位
  void delay_ms(uchar x)
  uchar i, j;
  i = 0;
  for(i=0; i《x; i++)
  j = 250;
  while(--j);
  j = 250;
  while(--j);
  uchar SPI_RW(uchar byte)
  uchar i;
  for(i=0; i《8; i++) // 循环8次
  MOSI = (byte & 0x80); // byte最高位输出到MOSI
  byte 《《= 1; // 低一位移位到最高位
  SCK = 1; // 拉高SCK,nRF24L01从MOSI读入1位数据,同时从MISO输出1位数据
  byte |= MISO; // 读MISO到byte最低位
  SCK = 0; // SCK置低
  return(byte); // 返回读出的一字节
  uchar SPI_RW_Reg(uchar reg, uchar value)
  uchar status;
  CSN = 0; // CSN置低,开始传输数据
  status = SPI_RW(reg); // 选择寄存器,同时返回状态字
  SPI_RW(value); // 然后写数据到该寄存器
  CSN = 1; // CSN拉高,结束数据传输
  return(status); // 返回状态寄存器
  uchar SPI_Read(uchar reg)
  uchar reg_val;
  reg_val = SPI_RW(0); // 然后从该寄存器读数据
  return(reg_val); // 返回寄存器数据
  uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
  uchar status, i;
  for(i=0; i《bytes; i++)
  pBuf = SPI_RW(0); // 逐个字节从nRF24L01读出
  uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
  uchar status, i;
  SPI_RW(pBuf); // 逐个字节写入nRF24L01
  void RX_Mode(void)
  CE = 0;
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 接收设备接收通道0使用和发送设备相同的发送地址
  SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 使能接收通道0自动应答
  SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 使能接收通道0
  SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 选择射频通道0x40
  SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // 接收通道0选择和发送通道相同有效数据宽度
  SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
  SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // CRC使能,16位CRC校验,上电,接收模式
  CE = 1; // 拉高CE启动接收设备
  void TX_Mode(uchar * BUF)
  CE = 0;
  SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写入发送地址
  SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 为了应答接收设备,接收通道0地址和发送地址相同
  SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH); // 写数据包到TX FIFO
  SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a); // 自动重发延时等待250us+86us,自动重发10次
  SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // CRC使能,16位CRC校验,上电
  CE = 1;
  uchar Check_ACK(bit clear)
  while(IRQ);
  sta = SPI_RW(NOP); // 返回状态寄存器
  if(MAX_RT)
  if(clear) // 是否清除TX FIFO,没有清除在复位MAX_RT中断标志后重发
  SPI_RW(FLUSH_TX);
  SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除TX_DS或MAX_RT中断标志
  IRQ = 1;
  if(TX_DS)
  return(0x00);
  else
  return(0xff);
  unsigned char nRF24L01_RxPacket(unsigned char* RX_BUF)
  unsigned char revale=0;
  //SetRX_Mode();
  sta=SPI_Read(STATUS); // read register STATUS‘s value
  if(RX_DR) // if receive data ready (RX_DR) interrupt
  CE = 0;
  SPI_Read_Buf(RD_RX_PLOAD,RX_BUF,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
  revale =1;//we have receive data
  SPI_RW_Reg(WRITE_REG+STATUS,sta);// clear RX_DR or TX_DS or MAX_RT interrupt flag
  return revale;
  void main(void)
  uchar a[5]={0xfe,0xfd,0xfc,0xf0,0x1d};
  uchar i;
  init_io(); // 初始化IO
  // RX_Mode(); // 设置为接收模式
  while(1)
  for(i=0;i《5;i++)
  TX_BUF = a; // 数据送到缓存
  TX_Mode(TX_BUF); // 把nRF24L01设置为发送模式并发送数据
  Check_ACK(1); // 等待发送完毕,清除TX FIFO
  delay_ms(250);
  delay_ms(250);
  // RX_Mode();
  nRF24L01的接收程序:
  #include 《reg51.h》
  sbit CE = P0^0; // Chip Enable pin signal (output)
  sbit CSN = P0^1; // Slave Select pin, (output to CSN, nRF24L01)
  sbit IRQ = P0^5; // Interrupt signal, from nRF24L01 (input)
  sbit MISO = P0^4; // Master In, Slave Out pin (input)
  sbit MOSI = P0^3; // Serial Clock pin, (output)
  sbit SCK = P0^2; // Master Out, Slave In pin (output)
  #define TX_PLOAD_WIDTH 4 // 数据通道有效数据宽度 因为这个4,导致发送接收的数据缺少第五个!改成5则正常!
  #define LED P1
  uchar flag;
  uchar DATA = 0x01;
  uchar bdata sta;
  sbit RX_DR = sta^6;
  sbit TX_DS = sta^5;
  void init_io(void)
  CE = 0; // 待机
  CSN = 1; // SPI禁止
  SCK = 0; // SPI时钟置低
  IRQ = 1; // 中断复位
  LED = 0xff; // 关闭指示灯
  uchar i, j;
  i = 0;
  for(i=0; i《x; i++)
  j = 250;
  while(--j);
  j = 250;
  while(--j);
  uchar i;
  SCK = 0; // SCK置低
  uchar status;
  uchar reg_val;
  uchar status, i;
  uchar status, i;
  void RX_Mode(void)
  CE = 0;
  CE = 0;
  CE = 1;
  while(IRQ);
  if(MAX_RT)
  SPI_RW(FLUSH_TX);
  IRQ = 1;
  if(TX_DS)
  return(0x00);
  else
  return(0xff);
  //SetRX_Mode();
  CE = 0;
  return revale;
  void main(void)
  uchar i;
  uchar reveal;
  init_io(); // 初始化IO
  while(1)
  reveal=nRF24L01_RxPacket(RX_BUF);
  if(reveal==1) // 接受完成
  reveal = 0;
  for(i=0;i《5;i++)
  LED = RX_BUF;
  delay_ms(250);
  delay_ms(250);
评论(0)
发评论
zjlei88 2022-04-24
0 回复 举报
pBuf = SPI_RW(0); // 逐个字节从nRF24L01读出这句编译出错,什么原因呢? 1条回复 收起回复
ImpulseWidth 0
改成pBuf[i]=SPI_RW(0);
