赛普拉斯低成本高可靠嵌入式闪存技术
1.2w人已加入
Outline
1. Charge-trap eNVMs at Cypress
2. SONOS
    –Introduction
    –Key Macro Specs
    –High Reliability
3. eCT
     –Introduction
     –Key Macro Specs
     –High Reliability
4. Embedded NVM Solutions for Various Applications
Cypress develops, uses and licenses two embedded NVM technologies
  • SONOS and eCT,both are charge-trap non-volatile memories.
SONOS: Silicon Oxide Nitride Oxide Silicon
  • Originally developed at Sandia National Lab, CY acquired it in 1998.
  • Available at 0.35µm, 0.13µm, 95nm, 65nm, 55nm, 40nm and 28nm process nodes.
  • Shipped>1,200,000 wafers from foundry partners HHGrace, HLMC and UMC.
  • Low cost, Lowpower, suitable for IoT, consumer, industrial, and automotive grade2/3 applications.
eCT : embedded  Charge Trap
  • Former Spansion’s eNVM technology for automotive MCUs.
  • Based on 6 generations of Mirror Bit technologies.
  • In production (MCUs) at 40 nm node at UMC.
  • Automotive Grade-1 qualified.
Key Features
SONOS Introduction
  • A planar, scalable MOS transistor with an ONO stack as the gate dielectric.
  • Store captured charges in discrete traps in the nitride (N) layer through FN tunneling.
Low Cost, Low Power, High Security
  • Lowest cost: Only 3~5 extra masks added into standard CMOS process.
低功耗
  • Lowest power: 7.5V program/erase voltage, low-current FN/FN program/erase operations.
  • High Security: Resistant to decode by de-processing.
  • Ideal solution for consumer, industrial and especially IoT SoCs.
> MCU, Smart Card,EEPROM, FPGA, NOR Flash, etc.
Key SONOS Macro Specs
低功耗
55 nm SONOS Macro Power Consumption
  • Balanced power consumption and performance (20ns Taa) for many applications
    Three power-saving modes: hibernate, sleep and standby.
    Low power read and program/erase operations to minimize active power.
    Low power read operation with Vdd=1.08 V to1.32 V.
低功耗
500hrs 225°C Yield w/ 50K Pre-cycling at 85 °C (55nm)
*All dies pass reading on full 8Mb after 500hrs 225°C bake
High Reliability
55-nm SONOS Macro Reliability
  • Endurance passes 500K cycles at 85°C w/o ECC. Vt window > 1.2V after     500K cycling.
  • Retention passes Automotive Grade-2 AEC Q100 requirement.
        > Vt window > 0.6 V after 500 hrs bake @ 225C with 50K pre-cycling.
低功耗低功耗
>滑动查看下一张图片<
40-nm SONOS Macro Reliability
低功耗低功耗
>滑动查看下一张图片<
28-nm SONOS Macro Reliability
  • Endurance passes 10K cycles at 125°C, Vt window >1.4 V after cycling.
  • Retention passes accelerated 48-hour bake at 250°C with > 0.7 V window left.
低功耗低功耗
>滑动查看下一张图片<
55nm SONOS in Production Press Release
Customers NPI Status @ HLMC 55nm SONOS
  • Engaged > 15 customers.
  • 7 Customers signed contract to use
  • 3 in mass production
  • > 1,000 wafers started per month
低功耗
SONOS eNVM Technology Availability
SONOS eNVM is scalable and proven in volume production on many nodes.
低功耗
eCT Introduction
  • Based on charge-trap technology proven in six generations of MirrorBit® NOR Flash memory
Ideal solution for high-performance automotive MCUs
  • Fast 8 ns random access time from -40°C to 150°C junction temperature and 30 ms word programming speed
  • Smallest eNVM bit cell in the industry, 0.053 sq. µm, at 40 nm node
  • Automotive Grade-1 reliability
Applications
  • Hybrid and electric vehicle motor control, instrument clusters, body control modules and HVAC
  • In volume production on UMC 40LP process flow
Key eCT Macro Specs
低功耗
 eCTReliability:
Automotive Qualification Data
  • Passed accelerated stress tests for Automotive Grade-1 per AEC-Q100 standard
低功耗
40nm eCT in Production Press Release
低功耗
Conclusion
Cypress develops and licenses charge-trap NVM technologies and Flash macro IP
  • Charge-trap NVMs serve in a wide range ofembedded applications
−SONOS: Consumer, Industrial SoCs
−eCT: high-performance automotive MCUs,Automotive Grade-1 reliability
  • Technologies are scalable to advanced nodes
−SONOS in mass production from 0.35um to 55nm, engineering samples available on 40uLP & 28HLP
−eCT is in volume production on UMC 40LP process
  • Low power for IoT: 0.9 V (40nm) or 1.2V(55nm) power supply, low-current operation, power-saving modes
  • Cost-effective: 3~5 (SONOS) or 8 (eCT)extra masks beyond the standard CMOS.
