六脚自锁开关介绍_六脚自锁开关引脚图及接法分析
继电器
148人已加入
六脚自锁开关就是两个单刀双掷开关,六脚自锁开关接法并不复杂。
六脚自锁开关引脚图
开关
六脚开关(六脚自锁开关)也就是我们说的双刀双掷开关,引脚共2排,每排3个引脚,中间一根是公共端,对应他左右2个脚一个常开一个常闭,另外一排和这个一样,常开对常开,公共点对公共点,常闭对常闭,但是是完全独立的2组,除非你在PCB上将他们连接起来才是通的
六脚自锁开关连接方法
1、用万用表调至二极管处;
2、先测量四角中的任意两脚,判断哪两个是导通的,哪两个是断开的;
3、按键按下,再测量任意两脚,判断哪两个是导通的,哪两个是断开的;
4、开始断开,按键按下导通的两脚可做为焊接的两个角,接线即可。
相关内容阅读推荐>>>>>>>>六脚开关引脚图及功能定义
评论(0)
发评论
qu123456 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/%25C6%25F3%25D2%25B5%252C%2B%25BD%25F5%25B8%25A3%25D3%25E9%25C0%25D6%25D7%25A2%25B2%25E1%25CB%25CD58B2024.cN%252C%25D1%25C5%25B0%25B2%25B5%25E7%25D0%25C5_99s.htm http://house.china.com.cn/sousou/%25B9%25D9%25B7%25BD%252C%2B%25B9%25FB%25B8%25D2%25BD%25F0%25B6%25A6%25B9%25FA%25BC%25CA%25BC%25AF%25CD%25C5B2024.cN_57s.htm http://house.china.com.cn/sousou/%25C9%25CF%25CF%25C2%25B7%25D6%252C%2B%25B2%25FD%25CA%25A2%25B9%25FA%25BC%25CA%25D3%25E9%25C0%25D6%25B3%25C7B2024.cN%252C%25C4%25CF%25D1%25F4%25C8%25C8%25CB%25D1_2s.htm http://house.china.com.cn/sousou/%25C0%25CF%25BD%25D6%252C%2B%25C3%25E5%25B5%25E9%25BB%25AA%25C4%25C9%25B9%25FA%25BC%25CA%25D5%25FD%25B9%25E6%25C2%25F0B2024.cN_29s.htm http://house.china.com.cn/sousou/%25C6%25F3%25D2%25B5%252C%2B%25B9%25FB%25B8%25D2%25CF%25ED%25C0%25FB%25BE%25C6%25B5%25EAB2024.cN%252C%25B3%25A4%25B4%25BA%25D2%25BD%25B1%25A3_67s.htm 收起回复
