用stm32控制4位数码管_stm32控制共阴数码管
数码管
8人已加入
1、stm32控制4位共阳数码管输出计数
用stm32控制4位数码管,需要用到GPIO口 PA0~PA11共12个引脚。首先我们来看看数码管的原理图。
STM32
STM32
因为是共阳所以12,9,8,6为电源输入,其他引脚均为接地,所以对于芯片来说12,9,8,6高位输出,其他设定为低位即可。
//设定下GPIO口
void GPIO_Num_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
这里有个要注意的,根据原理图可以看出数码管一次只能输出一位数组,所以如果是多位的必须使用扫描的方式输出,缩短切换的间隔,就可以达到不闪烁的效果。
//输出封装
void DisPlayNum(int n)
if (n 《 9999)
{ int i;
int s;
s = n;
i=0;
for (i=0;i《4;i++)
GPIO_ResetBits(GPIOA,GPIO_Pin_All);
switch (i)
case 0:
GPIO_SetBits(GPIOA,GPIO_Pin_5);
break;
case 1:
GPIO_SetBits(GPIOA,GPIO_Pin_7);
break;
case 2:
GPIO_SetBits(GPIOA,GPIO_Pin_8);
break;
case 3:
GPIO_SetBits(GPIOA,GPIO_Pin_11);
break;
switch (s % 10)
case 0:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_4);
break;
case 1:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_9|GPIO_Pin_10);
break;
case 2:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_9);
break;
case 3:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_9);
break;
case 4:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_10);
break;
case 5:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_6);
break;
case 6:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_6);
break;
case 7:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_9);
break;
case 8:
GPIO_SetBits(GPIOA,GPIO_Pin_2);
break;
case 9:
GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_0);
break;}
s = s / 10;
delay_ms(1);
if (s==0)
break;}}}
最后main的测试代码
int count;
int TimeCheck;
int main(void)
GPIO_Num_Init();
count =0;
TimeCheck = 0;
while(1)
DisPlayNum(count);
TimeCheck++;
delay_ms(5);
if (TimeCheck 》 100){ //每500毫秒+1
TimeCheck=0;
count++;}}}
2、stm32控制共阴数码管
共阴数码管
#include“stm32f10x.h”
u8table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f};//共阴数码管对应的编码
voiddelayms(u16 time)
u16 i=0;
while(time--)
i=12000;
while(i--);
voidInitStm32()
GPIO_InitTypeDefGPIO_InitStructure; //定义一个管脚初始化的结构体
//开启PA口时钟
GPIO_InitTypeDef DuanAndWeiMa;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);
//配置PAO的模式
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_All;
DuanAndWeiMa.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1; //为什么要用一杠 0是段码,1是位码
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
DuanAndWeiMa.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
DuanAndWeiMa.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOB,&DuanAndWeiMa);
intmain(void)
InitStm32();
while(1)
GPIO_SetBits(GPIOB,GPIO_Pin_1);
GPIO_Write(GPIOA,0xfe); //问题是:第8个数码管控制不了,一直显示的是8
GPIO_ResetBits(GPIOB,GPIO_Pin_1);
GPIO_SetBits(GPIOB,GPIO_Pin_0);
GPIO_Write(GPIOA,table[0]);
GPIO_ResetBits(GPIOB,GPIO_Pin_0);
delayms(2);
GPIO_Write(GPIOA,0xfd);
GPIO_Write(GPIOA,table[1]);
delayms(2);
GPIO_Write(GPIOA,0xfb);
GPIO_Write(GPIOA,table[2]);
delayms(2);
GPIO_Write(GPIOA,0xf7);
delayms(2);
