基于HT48R50A的LED点阵+LCD显示程序
控制/MCU
1813人已加入
 Function :   5X7 LED点阵+LCD显示示例程序   *
; MICroProcessor : HT48R50A-1/28SKDIP-A      *
HT48R50A
; Author:                      *
; Crystal :       4MHz                       *
#INCLUDE                HT48R50A-1.INC
LCD_DATA                EQU     PB
LCD_DATA_CTRL           EQU     PBC
LCD_CTRL                EQU     PC
LCD_CTRL_CTRL           EQU     PCC
E                       EQU     5
RS                      EQU     3
TIME_OUT                EQU     11H
CLR_WDT                 EQU     22H
EXE_HALT                EQU     33H
CLR_WDT1_WDT2           EQU     44H
DATA    .SECTION        AT 60H  ’DATA’
DELAY_COUNTER_1         DB      ?       ;[60H]
DELAY_COUNTER_2         DB      ?       ;[61H]
DELAY_COUNTER_3         DB      ?       ;[62H]
DATA                    DB      ?       ;[63H]
COUNTER                 DB      ?       ;[64H]
WARM_RESET              DB      ?       ;[65H]
DISPLAY_FLAG            DB      ?       ;[66H]
CODE    .SECTION        AT 00H  ’CODE’
                ORG     00H
                JMP     START
START:
                CLR     PAC
                CLR     LCD_DATA_CTRL
                CLR     LCD_CTRL_CTRL
                CLR     LCD_DATA
                CLR     LCD_CTRL
                 MOV      A,07H       ; set watch dog time out
                 MOV      WDTS,A      ; 2.6 sec
                CLR     WDT         ; clear watch dog timer
                 MOV      A,WARM_RESET
                 MOV      DISPLAY_FLAG,A
                SUB     A,TIME_OUT
                SZ      ACC
                JMP     CHK_CLR_WDT
                JMP     GO_TIME_OUT
CHK_CLR_WDT:
                 MOV      A,WARM_RESET
                 MOV      DISPLAY_FLAG,A
                SUB     A,CLR_WDT
                SZ      ACC
                JMP     CHK_EXE_HALT
                JMP     GO_CLR_WDT
CHK_EXE_HALT:
                 MOV      A,WARM_RESET
                 MOV      DISPLAY_FLAG,A
                SUB     A,EXE_HALT
                SZ      ACC
                JMP     CHK_CLR_WDT_12
                JMP     GO_EXE_HALT
CHK_CLR_WDT_12:
                 MOV      A,WARM_RESET
                 MOV      DISPLAY_FLAG,A
                SUB     A,CLR_WDT1_WDT2
                SZ      ACC
                JMP     BEGIN
                JMP     GO_CLR_WDT_12
BEGIN:
                CALL    LCD_RESET
GO_TIME_OUT:
                 MOV      A,CLR_WDT
                 MOV      WARM_RESET,A
                 MOV      A,OFFSET LCD_MESSAGE_1
                 MOV      TBLP,A
                CALL    LCD_DISPLAY
TIME_OUT_LOOP:
                CALL    LED_DISPLAY
                JMP     TIME_OUT_LOOP
                RET
GO_CLR_WDT:
                 MOV      A,EXE_HALT
                 MOV      WARM_RESET,A
                 MOV      A,OFFSET LCD_MESSAGE_2
                 MOV      TBLP,A
                CALL    LCD_DISPLAY
CLR_WDT_LOOP:
                CALL    LED_DISPLAY
                JMP     CLR_WDT_LOOP
                RET
GO_EXE_HALT:
                 MOV      A,CLR_WDT1_WDT2
                 MOV      WARM_RESET,A
                 MOV      A,OFFSET LCD_MESSAGE_3
                 MOV      TBLP,A
                CALL    LCD_DISPLAY
EXE_HALT_LOOP:
                CALL    LED_DISPLAY
                JMP     EXE_HALT_LOOP
                RET
GO_CLR_WDT_12:
                 MOV      A,TIME_OUT
                 MOV      WARM_RESET,A
                 MOV      A,OFFSET LCD_MESSAGE_4
                 MOV      TBLP,A
                CALL    LCD_DISPLAY
CLR_WDT_12_LOOP:
                CALL    LED_DISPLAY
                JMP     CLR_WDT_12_LOOP
                RET
LED_DISPLAY     PROC
                SET     PA
                CALL    DELAY
                 MOV      A,OFFSET SEGMENT_DATA
                 MOV      TBLP,A
                 MOV      A,10H
                 MOV      COUNTER,A
DISPLAY_START:
                TABRDL  DATA
                 MOV      A,DATA
                 MOV      PA,A
                CALL    DELAY
                INC     TBLP
                 MOV      A,DISPLAY_FLAG
                SUB     A,CLR_WDT
                SZ      ACC
                JMP     LED_CLR_WDT12
                CLR     WDT
                JMP     DISPLAY_END
LED_CLR_WDT12:
                 MOV      A,DISPLAY_FLAG
                SUB     A,CLR_WDT1_WDT2
                SZ      ACC
                JMP     LED_EXE_HALT
                CLR     WDT1
                CLR     WDT2
                JMP     DISPLAY_END
LED_EXE_HALT:
                 MOV      A,DISPLAY_FLAG
                SUB     A,EXE_HALT
                SZ      ACC
                JMP     DISPLAY_END
                HALT
DISPLAY_END:
                SDZ     COUNTER
                JMP     DISPLAY_START
                RET
LED_DISPLAY     ENDP
LCD_RESET       PROC
                 MOV      A,30H       ; LCD reset , step 1
                 MOV      LCD_DATA,A  ;
                CALL    WRITE       ;
                CALL    DELAY       ; LCD reset , step 2
                 MOV      A,30H       ; LCD reset , step 3
                 MOV      LCD_DATA,A  ;
                CALL    WRITE       ;
                CALL    DELAY       ; LCD reset , step 4
                 MOV      A,30H       ; LCD reset , step 5
                 MOV      LCD_DATA,A  ;
                CALL    WRITE       ;
                 MOV      A,38H       ; LCD setting , step 1
                 MOV      LCD_DATA,A  ; function set
                CALL    WRITE       ;
                 MOV      A,06H       ; LCD setting , step 2
                 MOV      LCD_DATA,A  ; entry mode set
                CALL    WRITE       ;
                 MOV      A,01H       ; LCD setting , step 3
                 MOV      LCD_DATA,A  ; display clear
                CALL    WRITE       ;
                CALL    DELAY       ;
                 MOV      A,0EH       ; LCD setting , step 4
                 MOV      LCD_DATA,A  ; display turn on
                CALL    WRITE       ;
                RET
LCD_RESET       ENDP
LCD_DISPLAY     PROC
                 MOV      A,01H       ; LCD setting , step 5
                CALL    WRITE       ;
                CALL    DELAY       ;
                 MOV      A,80H       ; LCD setting , setp 6
                 MOV      LCD_DATA,A  ; DD RAM address setting
                CALL    WRITE       ; address = 00h (first line)
                SET     LCD_CTRL.RS ; LCD setting , step 7
                 MOV      A,10H       ; write data to DD RAM
                 MOV      COUNTER,A
DISPLAY1:
                TABRDL  DATA
                 MOV      A,DATA
                 MOV      LCD_DATA,A
                CALL    WRITE
                INC     TBLP
                SDZ     COUNTER
                JMP     DISPLAY1
                CLR     LCD_CTRL.RS
                 MOV      A,0C0H      ; LCD setting , step 8
                CALL    WRITE       ; address = 40h (second line)
                SET     LCD_CTRL.RS ; LCD setting , step 9
                 MOV      COUNTER,A
DISPLAY2:
                TABRDL  DATA
                 MOV      A,DATA
                 MOV      LCD_DATA,A
                CALL    WRITE
                INC     TBLP
                SDZ     COUNTER
                JMP     DISPLAY2
                RET
LCD_DISPLAY     ENDP
WRITE           PROC
                SET     LCD_CTRL.E
                CLR     LCD_CTRL.E
                 MOV      A,0FFH
                 MOV      DELAY_COUNTER_1,A
WAIT:
                SDZ     DELAY_COUNTER_1
                JMP     WAIT
                RET
WRITE           ENDP
DELAY           PROC
                 MOV      A,003H
                 MOV      DELAY_COUNTER_2,A
                 MOV      DELAY_COUNTER_3,A
DELAY_WAIT:
                SDZ     DELAY_COUNTER_3
                JMP     DELAY_WAIT
                SDZ     DELAY_COUNTER_2
                JMP     DELAY_WAIT
                SDZ     DELAY_COUNTER_1
                JMP     DELAY_WAIT
                RET
DELAY           ENDP
                ORG     0F00H
LCD_MESSAGE_1:          ;[Now , watch dog ]
                        ;[will be time out]
                DC      4EH,6FH,77H,20H,2CH,20H,77H,61H
                DC      74H,63H,68H,20H,64H,6FH,67H,20H
                DC      77H,69H,6CH,6CH,20H,62H,65H,20H
                DC      74H,69H,6DH,65H,20H,6FH,75H,74H
LCD_MESSAGE_2:          ;[Without time out]
                        ;[Because CLR WDT ]
                DC      57H,69H,74H,68H,6FH,75H,74H,20H
                DC      42H,65H,63H,61H,75H,73H,65H,20H
                DC      43H,4CH,52H,20H,57H,44H,54H,20H
LCD_MESSAGE_3:          ;[Executing the   ]
                        ;[HALT instruction]
                DC      45H,78H,65H,63H,75H,74H,69H,6EH
                DC      67H,20H,74H,68H,65H,20H,20H,20H
                DC      48H,41H,4CH,54H,20H,69H,6EH,73H
                DC      74H,72H,75H,63H,74H,69H,6FH,6EH
LCD_MESSAGE_4:          ;[Without time out]
                        ;[CLR WDT1 & WDT2 ]
                DC      43H,4CH,52H,20H,57H,44H,54H,31H
                DC      20H,26H,20H,57H,44H,54H,32H,20H
SEGMENT_DATA:   ;7 SEGMENT DISPLAY DATA (COMMON ANODE)
                DC      081H,0CFH,092H,086H     ;0123
                DC      0CCH,0A4H,0A0H,08FH     ;4567
                DC      080H,084H,088H,0E0H     ;89AB
                DC      0B1H,0C2H,0B0H,0B8H     ;CDEF
                END
