SAMSUNG S3C9454 示例程序
//PROJECT : EA21
//IC      : SAMSUNG S3C9454
#include "ioS3C9454.h"
//自己编写,注意const    ?
// PIN define area
#define  CONTROL_RelayLight (P0&0x04)     //P0.2
#define  SET_RelayLight         (P0|=0x04)
#define  CLR_RelayLight         (P0&=0xFB)
#define  CONTROL_RelayCyclone (P0&0x08)     //P0.3
#define  SET_RelayCyclone (P0|=0x08)
#define  CLR_RelayCyclone        (P0&=0xF7)
//function declare area
void   io_init(void);
void   delay(void);
void   AD_CONV(void);
void   MOV ingData(void);
void   JudgingKey(void);
void   DealKey(void);
void   DealDelayClose(void);
void   DealDelayLOCk(void);
void   DealBuzz(void);
void   DealLockMotor(void);
void   ram_init(void);
//constant  define area
#define  DelayKey    0x01
#define  PowerKey    0x02
#define  CycloneKey  0x04
#define  LightKey    0x08
#define  LockKey     0x10
#define  BigWindKey  0x20
#define  SILenceKey  0x40
//variable define area
unsigned char VolData[7][5];     //如果上电前,即使按键按下,也不识别,那么,初始化为0就可以,
                                 //如果需要识别,就要处理??
unsigned char Key_OldStatus;     //表示前一时刻键的状态,1表示按下,0表示弹起
unsigned char RepeatKey_Status;  //表示重键的状态,1表示有,0表示无,对应七个键
unsigned char Key_NowPushStatus; //表示现在键按下的状态
#define  CONTROL_LockStatus  (SYS_Status&0x01)
#define  SET_LockStatus          (SYS_Status|=0x01)
#define  CLR_LockStatus    (SYS_Status&=0xFE)
//table define area
//code unsigned char AnalogChannel[7]={0x00,0x00,0x01,0x01,0x02,0x02,0x03};
//code unsigned char ADChannel[7]={0x05,0x15,0x05,0x15,0x05,0x15,0x15};
//SUB PROGRAM ROUTINE
void io_init(void)
 CLKCON = 0x18; // cpu clock is non-divided clock
 BTCON = 0xA3;   // dISAble watch-dog, select fxx/4096 for basic timer clock
                                //btcon = 0x02, enable watch-dog
 SP = 0xC0; // sp
