MSP430F1121与PCF8576驱动程序
#include  "MSP430x11x1.h"
#define uint unsigned int
#define uchar unsigned char
//器件地址
uchar    PCF8576=0x70;
//内存数据定义
uchar    ByteCnt;     //I2C 数据字节计数器
uchar    SlvAdr;        //被控器地址
uchar    SubAdr;        //被控器单元地址
uchar    XmtDat[5];    //发送数据缓冲区
//uchar    MODE1=0x45;
uchar    MODE2=0xCD;        //
uchar    Bank_sel=0x78;
uchar    flag;
uchar    Digit[10];
#define SDA      BIT3      // P2.3 controls SDA line (pull-up used for
logIC 1)
#define SCL   BIT4      // P2.4 controls SCL line (pull-up used for logic 1)
; 子程序
;名称:START
;描述:启动I2C 总线子程序--发送I2C 起始条件
void START(void)
    P2OUT |= SDA;        //SDA=1
    _NOP();
    P2OUT |= SCL;        //SCL=1
    _NOP();
    P2OUT &= ~SDA;        //SDA=0
    _NOP();
    P2OUT &= ~SCL;        //SCL=0
;名称:STOP
;描述:停止I2C 总线子程序--发送I2C 总线停止条件
void STOP(void)
    _NOP();
    P2OUT |= SCL;
    _NOP();
    P2OUT |= SDA;
    _NOP();
    P2OUT &= ~SCL;
void cack(void)        /* 应答位检查 */
    P2OUT |= SDA;
    P2OUT |= SCL;
    P2DIR &= ~SDA;
    _NOP();
    P2OUT &= ~SCL;
    P2DIR |= SDA;
void delay(uchar time)
uchar i;
do{
    for(i=100;i!=0;i--);
  } while(--time!=0);
;名称:SendByte
;描述:字节数据传送子程序发送一个字节数据或地址给被控器PCF8576
void SendByte(uchar Data)
uchar i=8;
    do
          if((Data&0x80)==0x80)
            P2OUT |= SDA;
          else
                 P2OUT &= ~SDA;
          P2OUT |= SCL;
        _NOP ();
          P2OUT &= ~SCL;
          Data=Data
