120VAC离线LED驱动器板ADM00766和LED负载板ADM00767主要特性详解(图)
电源/新能源
3399人已加入
microchip公司的CL88020是离线LED驱动器,输入电压120VAC,提供8.5W LED功率.器件包括CL88020 LED驱动器,六个电阻和桥式整流器.具有可编超温保护,允许THD优厚,可选择降低轻负载输出波纹,只使用一个外接陶瓷存储电容,TRIAC调光兼容,主要用在LED灯和LED照明固定装置.本文介绍了CL88020主要特性,框图和典型应用电路,以及120VAC离线LED驱动器板ADM00766和LED负载板ADM00767主要特性,电路图,材料清单和PCB设计图.
The CL88020 LED Driver Integrated Circuit (IC) is anoff-line sequential linear LED driver designed to provide8.5W of LED power from a 120 VAC nominal inputvoltage.
CL88020 is designed to drive a long string of inexpensive,low-current LEDs directly from the AC mains. Abasic driver circuit consists of Microchip TechnologyInc.’s CL88020 LED driver IC, six resistors and a bridgerectifier. Two to four additional components are optionalfor various levels of transient protection, also with alow-cost NTC to assure remote overtemperature protection(OTP). No capacitors, EMI filters, or power factorcorrection circuits are needed unless the optionalreduced light output ripple feature is desired.
A string of series/parallel LEDs is tapped at four locations.Four linear current regulators sink current at eachtap through a single control point and are sequentiallyturned on and off. High efficiency is achieved by shuttingoff upstream regulators when downstream regulatorsachieve regulation. This makes controlling overall input current easier than trying to control multiple currentpaths, thereby tracking the input sine wave voltage.
CL88020 uses a self-commutation techniqueusing only the tap currents themselves; this techniqueinherently provides smooth transitions from one regulatorto the next, without relying on tap voltages or therectified AC to coordinate the transitions.
CL88020主要特性:
• Optimized for 120 VAC Nominal Input Voltage
- 120VAC ± 15% input voltage
• Targeted for 8.5W Output Power
• Programmable Overtemperature Protection
- Provides Gradual Reduction in Light Outputwith Increasing Temperature
• Active Line Regulation
- Provides Fairly Constant Output Power overVariations in AC Line Voltage
- Typical Line Regulation of –12% to +0%
• Four Taps with Two Current Set Resistors
- Allows Optimization of THD
• Optional Reduced Light Output Ripple
- Provides Continuous Power to the LED
- Eliminates Strobing
- Uses an External Ceramic Storage Capacitor
• TRIAC Dimmer Compatible
• Available in a Thermally Enhanced 8-Lead SOICPackage with Heat Slug
- Larger Creepage Distances between HighVoltage and Low Voltage Pins
CL88020应用:
• LED Lamps
• LED Lighting Fixtures
led驱动器
图1.CL88020框图
led驱动器
图2.CL88020典型应用电路图
CL88020 120VAC离线LED驱动器板ADM00766和LED负载板ADM00767 The CL88020 120 VAC Offline LED Driver Evaluation Board is a complete solution consistingof an LED Driver (ADM00766) and an LED Load Board (ADM00767) powered directly from the 120VAC line and based on Microchip Technology’s CL88020 sequential linear LED driver. The application achieves efficient operation without using anymagnetics or conventional switching techniques and is a flexible solution that allowsusers to design and to test their own LED Load solution. The included LED Load ismade with 10 LEDs. Since no high frequencies are present, it exhibits inherently lowconducted and radiated EMI without needing input filters or shielding. Because the currentthrough the LEDs follows the AC input voltage, PFC circuitry is also not needed.
The CL88020 is inherently compatible with both leading-edge and trailing-edge dimmers,with no need for special circuitry to detect and respond to them.The LED Load is provided on a double-layer 60 mm diameter FR4 PCB (0.6 mm thick)mounted on a pin-fin heat sink. The LED Driver PCB (ADM00766) is made on 1.6 mm standard double-layer FR4. The kit includes an 8-wire flat cable to connect the LEDDriver Board to the LED Load, and a black anodized pin fin heat sink with double-sidedadhesive thermal tape necessary to mount the LED Load Board on it. All circuitry andhardware is provided, along with transient protection and overtemperature protection.Just plug into a 120 VAC outlet (50 Hz or 60 Hz) to get started.
LED驱动器评估板ADM00766主要特性:
• Input Voltage: 120 Vrms +/-15%, 50/60 Hz
• Typical Output Capability: up to 130 mA
• Efficiency: Over 83%
• Max Output Power: 8.5W (depends on the cooling provided)
LED负载板ADM00767主要特性:
• Contains 10 LEDs (GW P9LR31.EM) grouped in 4 taps
• An 8-wire flat cable input connector
• One NTC for overtemperature protection
CL88020 120VAC离线LED器评估板套件包括:
• CL88020 LED Driver Evaluation Board (ADM00766)
• 8-wire interconnection flat cable
• 4 nylon stand-offs with corresponding screw
• Important Information Sheet
CL88020LED负载板ADM00767包括:
• CL88020 LED Load Board (ADM00767)
• LED Load pin fin heat sink
• Thermal double-sided adhesive tape
led驱动器
图3.CL88020 120VAC离线LED器评估板(源板)外形图
led驱动器
图4.CL88020 LED负载板外形图
led驱动器
图5.连接图
led驱动器
图6.LED驱动器评估板ADM00766电路图
led驱动器
图7.CL88020离线LED驱动器应用电路
LED驱动器评估板ADM00766材料清单:
led驱动器
led驱动器
L88020 LED负载板材料清单:
led驱动器
led驱动器
图8.L88020LED驱动器评估板ADM00766PCB设计图(1)
led驱动器
图9.L88020LED驱动器评估板ADM00766PCB设计图(2)
led驱动器
图10.L88020LED驱动器评估板ADM00766PCB设计图(3)
led驱动器
图11.L88020 LED驱动器评估板ADM00766PCB设计图(4)
led驱动器
图12.L88020 LED驱动器评估板ADM00766PCB设计图(5)
led驱动器
图13.L88020 LED驱动器评估板ADM00766PCB设计图(6)
led驱动器
图14.L88020 LED负载板ADM00767 PCB设计图(1)
led驱动器
图15.L88020 LED负载板ADM00767 PCB设计图(2)
led驱动器
图16.L88020 LED负载板ADM00767 PCB设计图(3)
led驱动器
图17.L88020 LED负载板ADM00767 PCB设计图(4)
led驱动器
图18.L88020 LED负载板ADM00767 PCB设计图(5)
图19.L88020 LED负载板ADM00767 PCB设计图(6)
