NC7NZ17 pdf datasheet (TinyLog
消耗积分:3 | 格式:rar | 大小:333 | 2008-08-06
王芳
分享资料个
NC7NZ17
TinyLogic UHS Triple Buffer
with Schmitt Trigger Inputs
General Description
The NC7NZ17 is a triple buffer with Schmitt trigger inputs
from Fairchild’s Ultra High Speed Series of TinyLogic in
the US8 package. The device is fabricated with advanced
CMOS technology to achieve ultra high speed with high
output drive while maintaining low static power dissipation
over a very broad VCC operating range. The device is
specified to operate over the 1.65V to 5.5V VCC range. The
inputs and outputs are high impedance when VCC is 0V.
Inputs tolerate voltages up to 7V independent of VCC operating
voltage. Schmitt trigger inputs typically achieve 1V
hysteresis between the positive going and negative going
input threshold voltage at 5V VCC.
Features
 Space saving US8 surface mount package
 MicroPak leadless package
 Ultra High Speed: tPD 3.6 ns Typ into 50 pF at 5V VCC
 High Output Drive: ±24 mA at 3V VCC
 Broad VCC Operating Range; 1.65V to 5.5V
 Power down high impedance inputs/outputs
 Overvoltage tolerant inputs facilitate 5V to 3V translation
 Patented noise/EMI reduction circuitry implemented
评论(0)
发评论
下载排行榜
