LT3964主要特性 同步降压LED驱动器解决方案
工业控制
1104人已加入
Linear公司的LT396是具有I2C接口的双路同步降压DC疍C转换器,工作在恒流和恒压源模式,非常适合于LED驱动器.工作电压4V-36V,恒流稳流±3%,1000:1外接真彩色PWM调光,10:1外接模拟调光,可调开关频率200kHz-2MHz,主要用在通用,工业,医疗和汽车照明,恒流和恒压源.本文介绍了LT3964主要特性,框图和多种应用电路,以及演示板DC2424A主要特性,电路图和材料清单.
The LTR3964 is a dual synchronous step-down DC/DCconverter with I2C interface designed to operate as aconstant-current and constant-voltage source and is idealfor driving LEDs. The fixed frequency and peak currentmode topology result in stable operation over a wide rangeof supply and output voltages. The ground referred voltage FB pin serves as the input for several LED protectionfeatures, and also allows the converter to operate as aconstant-voltage source. The maximum output current isset by an external resistor, and the output current amplifierhas a rail-to-rail common mode range. LT3964 usesan I2C interface to communicate with a microcontrollerto read LED faults, write PWM and analog dimming registersand set fault masking. The I2C PWM input providesLED dimming ratios up to 8192:1. The I2C programmableCTRL register sets the gain of the external CTRL pin, andmaximum current sense threshold, providing additional analog dimming capability.
LT3964主要特性:
Wide Input Voltage Range: 4V to 36V
Two Independent 1.6A/40V Synchronous Bucks
I2C Interface for Internal True Color PWM™ Dimming(8192:1), Analog Dimming and Fault Reporting
1000:1 External True Color PWM Dimming and10:1 External Analog Dimming
PMOS Switch Driver for PWM and Output Disconnect
±3% Constant Current Regulation
Adjustable Frequency: 200kHz to 2MHz
Frequency Synchronization with Clock Output
Programmable OPENLED Protection with Reporting
Short-Circuit Protection with Reporting
Programmable Undervoltage Lockout with Hysteresis
Internal Compensation
9 Unique Device Addresses for I2C
Available in 5mm × 6mm 36-Lead QFN Package
LT3964应用:
General Purpose, Industrial, Medical andAutomotive Lighting
Constant-Current, Constant-Voltage Source
led驱动器
图1.LT3964框图
led驱动器
图2.LT3964应用电路(1):50W双路降压1A LED驱动器
led驱动器
图3.LT3964应用电路(2):带PWM调光50W双路降压1A LED驱动
led驱动器
图4.LT3964应用电路(3):多路升压/降压倒LED驱动器
led驱动器
图5.LT3964应用电路(4):矩阵LED驱动器
演示板DC2424A
The DC2424A is a 36V synchronous dual LED driver withI2C featuring the LT®3964. It drives two separate LEDs(or channels of LEDs) at 1A when VIN is between 5Vand 36V. DC2424A runs at 2MHz switching frequency.
Its two channels can drive separate LED strings whichcan have different currents, voltages, or dimming ratios.It can be controlled with I2C communications or it canbe run in non-I2C mode with proper ADDR pin settings.
It is protected against both open and short LED conditionsand reports the faults. In I2C mode, faults can beenabled or disabled. Up to 9 different DC2424As can beplaced on the same I2C bus with unique addresses. Agraphical user interface (GUI) is available through QuikEval™ when connected to a DC2026C Linduino® Onedemo circuit.
The LT3964 has an input voltage range from 4V to 36V. Ithas two independent 1.6A, 40V bucks with internal, synchronous40V switches for high efficiency and small size.
It has adjustable switching frequency between 200kHzand 2MHz. It can be synchronized to an external sourceor programmed with a clock output (CLKOUT) from theserial interface. The PWMTG high side PWM MOSFETdrivers assist with short-circuit protection and versatility.
Although the demo circuit is optimized for just one LEDper channel, it can be altered to be buck regulators withas high as 33V of LEDs if VIN is high enough and circuitcomponents are changed appropriately.
In non-I2C mode, each channel can separately be PWMandanalog-dimmed by placing a PWM signal or CTRLvoltage on the provided turrets. In I2C mode, each channelcan be dimmed to up to 8192:1 and analog dimmed to ahigh ratio using serial communications. Small ceramic input and output capacitors are used tosave space and cost. The open LED overvoltage protectionuses the IC’s constant voltage regulation loop to regulatethe output to approximately 4.2V if the LED stringis opened. There is a protection diode from each LED+to GND to prevent negative ringing during a short-circuitcondition.
Undervoltage lockout can be adjusted on the circuit with afew simple resistor choices. The output voltage (overvoltageprotection) can be adjusted by changing the feedback resistors for higher string voltages. Other componentsmay need to be changed to accommodate higher voltagesalso.
The LT3964 data sheet gives a complete description ofthe device, operation and applications information. Thedata sheet must be read in conjunction with this demomanual for DC2424A. The LT3964EUHE is assembled in a36-lead plastic 5mmx6mm QFN package with a thermallyenhanced ground pad. Proper board layout is essentialfor maximum thermal performance. See the data sheetLayout Considerations section.
led驱动器
图6.演示板DC2424A测试建立图
led驱动器
图7.演示板DC2424A电路图
演示板DC2424A材料清单:
led驱动器
