FPGA二值图像边界提取算法实现
FPGA/ASIC技术
190人已加入
1 背景知识
图1 二值图像边界提取演示
如图1 所示,图1 a为一幅简单的二值图像,经过边界提取后形成如图1 b 所示的图像,显示出了白色区域的轮廓。
2 边界提取算法
使用黑色提取,背景为白色,‘1’表示白色,‘0’表示黑色。
FPGA
图2 二值图像边界提取演示
我们使用3x3模板进行边界提取,所以当3x3九个点都是‘1’的时候,输出为‘1’,当九个点都是‘0’的时候,输出为‘1’,其他情况输出均为‘0’。
3 FPGA二值图像边界提取算法实现
FPGA
图2 二值图像膨胀FPGA模块架构
图2中我们使用串口传图传入的是二值图像。
FPGA源码:
Module name:  boundary_extraction.v
Description:  binary image boundary extraction
`timescale 1ns/1ps
module boundary_extraction(
       input             clk,  //pixel clk
input             rst_n,
input             hs_in,
input             vs_in,
input [15:0]      data_in,
input             data_in_en,
output            hs_out,
output            vs_out,
output  reg [15:0]    data_out,
output            data_out_en
wire [15:0] line0;
wire [15:0] line1;
wire [15:0] line2;
reg [15:0] line0_data0;
reg [15:0] line0_data1;
reg [15:0] line0_data2;
reg [15:0] line1_data0;
reg [15:0] line1_data1;
reg [15:0] line1_data2;
reg [15:0] line2_data0;
reg [15:0] line2_data1;
reg [15:0] line2_data2;
reg        data_out_en0;
reg        data_out_en1;
reg        data_out_en2;
reg        hs_r0;
reg        hs_r1;
reg        hs_r2;
reg        vs_r0;
reg        vs_r1;
reg        vs_r2;
wire[18:0]  result_data;
line3x3 line3x3_inst(
        .clken(data_in_en),
     .clock(clk),
     .shiftin(data_in),
     .shiftout(),
     .taps0x(line0),
     .taps1x(line1),
     .taps2x(line2)
// Form an image matrix of three multiplied by three
always @(posedge clk or negedge rst_n) begin
  if(!rst_n) begin
    line0_data0 <= 16'b0;
line0_data1 <= 16'b0;
line0_data2 <= 16'b0;
line1_data0 <= 16'b0;
line1_data1 <= 16'b0;
line1_data2 <= 16'b0;
line2_data0 <= 16'b0;
line2_data1 <= 16'b0;
line2_data2 <= 16'b0;
data_out_en0 <= 1'b0;
data_out_en1 <= 1'b0;
data_out_en2 <= 1'b0;
hs_r0 <= 1'b0;
hs_r1 <= 1'b0;
hs_r2 <= 1'b0;
vs_r0 <= 1'b0;
vs_r1 <= 1'b0;
vs_r2 <= 1'b0;
  end
  else if(data_in_en) begin
    line0_data0 <= line0;
line0_data1 <= line0_data0;
line0_data2 <= line0_data1;
line1_data0 <= line1;
line1_data1 <= line1_data0;
line1_data2 <= line1_data1;
line2_data0 <= line2;
line2_data1 <= line2_data0;
line2_data2 <= line2_data1;
data_out_en0 <= data_in_en;
data_out_en1 <= data_out_en0;
data_out_en2 <= data_out_en1;
    hs_r0 <= hs_in;
hs_r1 <= hs_r0;
hs_r2 <= hs_r1;
vs_r0 <= vs_in;
vs_r1 <= vs_r0;
vs_r2 <= vs_r1;
  end
end
// line0_data0   line0_data1   line0_data2
// line1_data0   line1_data1   line1_data2
// line2_data0   line2_data1   line2_data2
  if(!rst_n)
    data_out <= 16'h0000;
  else if(data_out_en1)
    if((line0_data0 == 16'h0000) && (line0_data1 == 16'h0000) && (line0_data2 == 16'h0000) && (line1_data0 == 16'h0000) && (line1_data1 == 16'h0000) && (line1_data2 == 16'h0000) && (line2_data0 == 16'h0000) && (line2_data1 == 16'h0000) && (line2_data2 == 16'h0000))
      data_out <= 16'hffff;
    else if((line0_data0 == 16'hffff) && (line0_data1 == 16'hffff) && (line0_data2 == 16'hffff) && (line1_data0 == 16'hffff) && (line1_data1 == 16'hffff) && (line1_data2 == 16'hffff) && (line2_data0 == 16'hffff) && (line2_data1 == 16'hffff) && (line2_data2 == 16'hffff))
    else
end
endmodule
4实验结果
FPGA
图5 实验原图1
图6实验原图2
图7 实验结果图1
图8 实验结果图2
结果分析:图5和图7对比,比较粗的线都被查找出了边缘,只有最细的那条没有被提取出来,并且被加粗,原因是最细的线条只有三个像素当查找出边缘后显示为黑色,两边黑色连在一起所以线条就变粗了。图6和图8边缘查找没有问题。
