C51读写AT24C04源代码及AT24C04测试程序
1.2w人已加入
 一、C51读写AT24C04源代码
  /*;起动24C01时序*/
  void Start()
  SCL=1;
  SDA=1;
  SDA=0;
  SCL=0;
  /*;停止24C01时序*/
  void Stop()
  SDA=0;
  SCL=1;
  SDA=1;
  /*;检测24C01的响应信号*/
  bit ACK()
  bit c;
  SDA=1;
  SCL=1;
  c=SDA;
  SCL=0;
  return c;
  /*;往24C01发一8位数据*/
  void SendChar(unsigned char ch)
  unsigned char i;
  i=8;
  do
  SDA=(ch&0x80);
  SCL=1;
  SCL=0;
  ch《《=1;
  }while(--i!=0);
  /*;从24C01接收一8位数据*/
  unsigned char RecChar()
  unsigned char i,j;
  i=8;
  do
  SCL=1;
  j=(j《《1)|SDA;
  SCL=0;
  }while(--i!=0);
  return j;
  /*;往24C01写一字节*/
  void WriteChar(unsigned int addr,unsigned char ch)
  unsigned char c;
  c=((*((unsigned char *)&addr))《《1)&0x02;
  Start();
  SendChar(0xa0|c);
  ACK();
  SendChar(addr);
  ACK();
  SendChar(ch);
  ACK();
  Stop();
  // for(addr=4;addr!=0;addr--)
  for(ch=0xff;ch!=0;ch--) ;
  /*;往24C01写多字节*/
  void WriteBuf(unsigned int addr,unsigned char idata *buf,unsigned char count)
  unsigned char c;
  Start();
  SendChar(0xa0|c);
  ACK();
  SendChar(addr);
  ACK();
  do
  SendChar(*buf++);
  ACK();
  if(count!=1)
  {if(((++addr)&0x7)==0)
  Stop();
  for(c=0xff;c!=0;c--) ;
  Start();
  SendChar(0xa0|c);
  ACK();
  SendChar(addr);
  ACK();
  else
  Stop();
  }while(--count!=0);
  /*;从24C01读一字节*/
  /*;入口:R0中为要读出内容的地址*/
  /*;出口:A中为读到的内容*/
  unsigned char ReadChar(unsigned int addr)
  unsigned char ch;
  ch=((*((unsigned char *)&addr))《《1)&0x02;
  Start();
  SendChar(0xa0|ch);
  ACK();
  SendChar(addr);
  ACK();
  Start();
  SendChar(0xa1|ch);
  ACK();
  ch=RecChar();
  Stop();
  return ch;
  /*至少读2字节*/
  void ReadBuf(unsigned int addr,unsigned char idata *buf,unsigned char count)
  unsigned char ch;
  Start();
  SendChar(0xa0|ch);
  ACK();
  SendChar(addr);
  ACK();
  Start();
  SendChar(0xa1|ch);
  ACK();
  count--;
  do
  *buf++=RecChar();
  SDA=0;
  SCL=1;
  SCL=0;
  SDA=1;
  }while(--count!=0);
  *buf=RecChar();
  Stop();
  二、AT24C04测试程序
  主芯片 : STC12C5A60S2 (1T)
  工作频率: 12.000MHz
  #include “REG51.H”
  #include “INTRINS.H”
  typedef unsigned char BYTE;
  typedef unsigned short WORD;
  sbit SCL = P3^4; //AT24C04的时钟
  sbit SDA = P3^5; //AT24C04的数据
  BYTE BUF[16]; //数据缓存区
  BYTE code TESTDATA[] =
  0x00,0x11,0x22,0x33,0x44,0x55,0x66,0x77,
  0x88,0x99,0xAA,0xBB,0xCC,0xDD,0xEE,0xFF
  void Delay5us();
  void Delay5ms();
  void AT24C04_Start();
  void AT24C04_Stop();
  void AT24C04_SendACK(bit ack);
  bit AT24C04_RecvACK();
  void AT24C04_SendByte(BYTE dat);
  BYTE AT24C04_RecvByte();
  void AT24C04_ReadPage();
  void AT24C04_WritePage();
  void main()
  Delay5ms();
  AT24C04_ReadPage();
  while (1);
  向AT24C04写1页(16字节)数据
  将TESTDATA开始的16个测试数据写如设备的00~0F地址中
  BYTE i;
  AT24C04_Start(); //起始信号
  AT24C04_SendByte(0xa0); //发送设备地址+写信号
  AT24C04_SendByte(0x00); //发送存储单元地址
  for (i=0; i《16; i++)
  AT24C04_SendByte(TESTDATA[i]);
  AT24C04_Stop(); //停止信号
  从AT24C04读取1页(16字节)数据
  将设备的00~0F地址中的数据读出存放在DATA区的BUF中
  BYTE i;
  AT24C04_SendByte(0xa1); //发送设备地址+读信号
  BUF[i] = AT24C04_RecvByte();
  if (i == 15)
  AT24C04_SendACK(1); //最后一个数据需要会NAK
  else
  AT24C04_SendACK(0); //回应ACK
  延时5微秒(STC12C5A60S2@12M)
  不同的工作环境,需要调整此函数
  此延时函数是使用1T的指令周期进行计算,与传统的12T的MCU不同
  void Delay5us()
  BYTE n = 4;
  while (n--)
  _nop_();
  _nop_();
  延时5毫秒(STC12C5A60S2@12M)
  不同的工作环境,需要调整此函数
  void Delay5ms()
  WORD n = 2500;
  while (n--)
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  起始信号
  SDA = 1; //拉高数据线
  SCL = 1; //拉高时钟线
  Delay5us(); //延时
  SDA = 0; //产生下降沿
  Delay5us(); //延时
  SCL = 0; //拉低时钟线
  停止信号
  void AT24C04_Stop()
  SDA = 0; //拉低数据线
  SCL = 1; //拉高时钟线
  Delay5us(); //延时
  SDA = 1; //产生上升沿
  Delay5us(); //延时
  发送应答信号
  入口参数:ack (0:ACK 1:NAK)
  SDA = ack; //写应答信号
  SCL = 1; //拉高时钟线
  Delay5us(); //延时
  SCL = 0; //拉低时钟线
  Delay5us(); //延时
  接收应答信号
  SCL = 1; //拉高时钟线
  Delay5us(); //延时
  CY = SDA; //读应答信号
  SCL = 0; //拉低时钟线
  Delay5us(); //延时
  return CY;
  向IIC总线发送一个字节数据
  BYTE i;
  for (i=0; i《8; i++) //8位计数器
  dat 《《= 1; //移出数据的最高位
  SDA = CY; //送数据口
  SCL = 1; //拉高时钟线
  Delay5us(); //延时
  SCL = 0; //拉低时钟线
  Delay5us(); //延时
  AT24C04_RecvACK();
  从IIC总线接收一个字节数据
  BYTE i;
  BYTE dat = 0;
  SDA = 1; //使能内部上拉,准备读取数据
  dat 《《= 1;
  SCL = 1; //拉高时钟线
  Delay5us(); //延时
  dat |= SDA; //读数据
  SCL = 0; //拉低时钟线
  Delay5us(); //延时
  return dat;
