AWR1243主要特性 功能_PCB设计图
汽车电子
2300人已加入
TI公司的AWR1243是单片77GHz和79GHz频率调制连续波(FMCW)收发器,具有基于分数N PLL的超精密啁啾引擎,简化了汽车雷达传感器在76-81GHz的实现方案.采用低功耗45nm RFCMOS工艺,单片实现了内置PLL和A2D转换器的3TX,4RX系统.TX发送功率12dBm,RX噪音15dB (76-77GHz), 16dB(77-81GHz),1MHz时的相位噪音–94 dBc/Hz (76-77 GHz),–91 dBc/Hz (77 - 81 GHz),内置了校准和自测试等功能.主要用在自动高速公路驾驶,自动紧急刹车和自适应巡航控制.本文介绍了AWR1243主要特性,功能框图,短中远距离雷达框图,参考电路,以及AWR1443 BoosterPack™评估板主要特性,框图,电路图,材料清单和PCB设计图.
The AWR1243 device is an integrated single-chip FMCW transceiver capable of operation in the 76- to 81-GHz band. The device enables unprecedented levels of integration in an extremely small form factor. AWR1243 is an ideal solution for low power, self-monitored, ultra-accurate radar systems in the automotive space.
The AWR1243 device is a self-contained FMCW transceiver single-chip solution that simplifies the implementation of Automotive Radar sensors in the band of 76 to 81 GHz. It is built on TI’s low-power 45-nm RFCMOS process, which enables a monolithic implementation of a 3TX, 4RX system with built-in PLL and A2D converters. Simple programming model changes can enable a wide variety of sensor implementation (Short, Mid, Long) with the possibility of dynamic reconfiguration for implementing a multimode sensor. Additionally, the device is provided as a complete platform solution including reference hardware design, software drivers, sample configurations, API guide, and user documentation.
AWR1243主要特性:
FMCW Transceiver
Integrated PLL, Transmitter, Receiver, Baseband, and A2D
76- to 81-GHz Coverage With 4 GHz Available Bandwidth
Four Receive Channels
Three Transmit Channels (Two Can be Used Simultaneously)
Ultra-Accurate Chirp Engine Based on Fractional-N PLL
TX Power: 12 dBm
RX Noise Figure:
15 dB (76 to 77 GHz)
16 dB (77 to 81 GHz)
Phase Noise at 1 MHz:
–94 dBc/Hz (76 to 77 GHz)
–91 dBc/Hz (77 to 81 GHz)
Built-in Calibration and Self-Test
Built-in Firmware (ROM)
Self-calibrating System Across Frequency and Temperature
Host Interface
Control Interface With External Processor Over SPI
Data Interface With External Processor Over MIPI D-PHY and CSI2 V1.1
Interrupts for Fault Reporting
ASIL B Capable
AECQ100 Qualified
AWR1243 Advanced Features
Embedded Self-monitoring With No Host Processor Involvement
Complex Baseband Architecture
Option of Cascading Multiple Devices to Increase Channel Count
Embedded Interference Detection Capability
Power Management
Built-in LDO Network for Enhanced PSRR
I/Os Support Dual Voltage 3.3 V/1.8 V
Clock Source
40.0-MHz Crystal With Internal Oscillator
Supports External Oscillator at 40 and 50 MHz
Easy Hardware Design
0.65-mm Pitch, 161-Pin 10.4 mm × 10.4 mm Flip Chip BGA Package for Easy Assembly and Low-Cost PCB Design
Small Solution Size
Supports Automotive Temperature Operating Range
AWR1243应用:
• Automated Highway Driving
• Automatic Emergency Braking
• Adaptive Cruise Control
传感器
图1.AWR1243功能框图
传感器
图2.AWR1243短中远距离雷达框图
传感器
图3.AWR1243参考电路图
传感器
图4.AWR1243低噪音LDO电路图
传感器
图5.AWR1243参考电路PCB布局图(顶层)
传感器
图6.AWR1243参考电路PCB布局图(顶层放大图)
传感器
图7.AWR1243参考电路PCB布局图(底层)
The AWR1443 BoosterPack™ is an easy-to-use evaluation board for the single-chip AWR1443 mmWavesensing device from TI, with direct connectivity to the TI MCU LaunchPad™ ecosystem. The evaluationboard contains everything needed to start developing on a low-power ARM®-R4F controller. Theevaluation board includes onboard emulation for programming and debugging, onboard buttons, andLEDs, for quick integration of a simple user interface. The standard 20-pin BoosterPack headers make the evaluation board compatible with a wide variety of TI MCU LaunchPads and enables easy prototyping.
The AWR1243 BoosterPack is an evaluation board for the AWR1243 mmWave high-performance frontend. The evaluation platform enables raw capture of ADC data from the front end and evaluation of RFperformance.
AWR1443 BoosterPack™评估板主要特性:
• 40-pin LaunchPad standard that leverages the LaunchPad ecosystem
• XDS110-based JTAG emulation with serial port, for onboard QSPI flash programming (for AWR1443)
• Backchannel UART through USB to PC, for logging purposes
• Onboard antenna
• 60-pin high density (HD) connector, for raw ADC data over CSI, or the high-speed debug interface
• Onboard CAN transceiver (for AWR1443)
• One button and two LEDs, for user interaction
• 5-V power jack, to power the board
AWR1443 BoosterPack™评估板包括:
• AWR1443BOOST or AWR1243BOOST
• Mounting brackets, screws, and nuts, to allow placing the PCB vertical
• Mirco USB cable to connect to the PC
传感器
图8.AWR1443 BoosterPack™评估板外形图
传感器
图9.AWR1443 BoosterPack™评估板框图
传感器
图10.AWR1443 BoosterPack™评估板电路图(1)
传感器
图11.AWR1443 BoosterPack™评估板电路图(2)
传感器
图12.AWR1443 BoosterPack™评估板电路图(3)
传感器
图13.AWR1443 BoosterPack™评估板电路图(4)
传感器
图14.AWR1443 BoosterPack™评估板电路图(5)
传感器
图15.AWR1443 BoosterPack™评估板电路图(6)
传感器
图16.AWR1443 BoosterPack™评估板电路图(7)
传感器
图17.AWR1443 BoosterPack™评估板电路图(8)
传感器
图18.AWR1443 BoosterPack™评估板电路图(9)
传感器
图19.AWR1443 BoosterPack™评估板电路图(10)
传感器
图20.AWR1443 BoosterPack™评估板电路图(11)
传感器
图21.AWR1443 BoosterPack™评估板电路图(12)
传感器
图22.AWR1443 BoosterPack™评估板电路图(13)
传感器
图23.AWR1443 BoosterPack™评估板电路图(14)
传感器
图24.AWR1443 BoosterPack™评估板电路图(15)
传感器
图25.AWR1443 BoosterPack™评估板PCB设计图(1)
传感器
图26.AWR1443 BoosterPack™评估板PCB设计图(2)
