三相马达驱动用的栅极驱动器DRV8305-Q1的主要特性
汽车电子
2296人已加入
  TI公司的DRV8305-Q1是三相马达驱动用的栅极驱动器,提供三个半桥驱动器,每个能驱动高边和低边N沟MOSFET;电荷泵驱动器支持100%占空比。器件满足AEC-Q100标准,4.4-V 到45-V工作电压,栅极峰值电流1.25A和1A,工作温度–40℃到150℃,主要用在三相BLDC和PMSM马达,汽车油泵和水泵,风扇和鼓风电动机。本文介绍了DRV8305-Q1主要特性,功能框图,典型应用电路图以及DRV8305-Q1EVM汽车三相马达栅极驱动评估模块主要特性,框图,电路图和材料清单。
  The DRV8305-Q1 device is a gate driver IC for three-phase motor-drive applications. The device provides three high-accuracy half-bridge drivers, each capable of driving a high-side and low-side N-channel MOSFET. A charge pump driver supports 100% duty cycle and low-voltage operation for cold crank situations. The device can tolerate load dump voltages up to 45-V.
  The DRV8305-Q1 device includes three bidirectional current-shunt amplifiers for accurate low-side current measurements that support variable gain settings and an adjustable offset reference.
  The DRV8305-Q1 device has an integrated voltage regulator to support an MCU or other system power requirements. The voltage regulator can be interfaced directly with a LIN physical interface to allow low-system standby and sleep currents.
  The gate driver uses automatic handshaking when switching to prevent current shoot through. The VDS of both the high-side and low-side MOSFETs is accurately sensed to protect the external MOSFETs from overcurrent conditions. The SPI provides detailed fault reporting, diagnostics, and device configurations such as gain options for the current shunt amplifier, individual MOSFET overcurrent detection, and gate-drive slew-rate control.
  Device Options:
  DRV8305NQ: Grade 1 with voltage reference
  DRV83053Q: Grade 1 with 3.3-V, 50-mA LDO
  DRV83055Q: Grade 1 with 5-V, 50-mA LDO
  DRV8305NE: Grade 0 with voltage reference
  DRV8305-Q1主要特性:
  AEC-Q100 Qualified for Automotive Applications
  Ambient Operating Temperature Ranges:
  Temperature Grade 0(E): –40℃ to 150℃
  Temperature Grade 1(Q): –40℃ to 125℃
  4.4-V to 45-V Operating Voltage
  1.25-A and 1-A Peak Gate Drive Currents
  Smart Gate Drive Architecture (IDRIVE & TDRIVE)
  Programmable High- and Low-Side Slew-Rate Control
  Charge-Pump Gate Driver for 100% Duty Cycle
  Three Integrated Current-Shunt Amplifiers
  Integrated 50-mA LDO (3.3-V and 5-V Option)
  3-PWM or 6-PWM Input Control up to 200 kHz
  Single PWM-Mode Commutation Capability
  Serial Peripheral Interface (SPI) for Device Settings and Fault Reporting
  Thermally-Enhanced 48-Pin HTQFP
  Protection Features:
  Fault Diagnostics and MCU Watchdog
  Programmable Dead-Time Control
  MOSFET Shoot-Through Prevention
  MOSFET VDS Overcurrent Monitors
  Gate-Driver Fault Detection
  Reverse Battery-Protection Support
  Limp Home-Mode Support
  Overtemperature Warning and Shutdown
  DRV8305-Q1应用:
  Three-Phase BLDC and PMSM Motors
  Automotive Fuel and Water Pumps
  Automotive Fans and Blowers
TI公司
图1.DRV8305-Q1功能框图
TI公司
  图2.DRV8305-Q1典型应用电路图
  The DRV8305-Q1EVM evaluation module (EVM) is a 4.4 V to 45 V, 25 A, 3-phase motor drive and control system based on the DRV8305-Q1 automotive motor gate driver, TMS320F28027 motor control microcontroller, and CSD18540Q5B NexFET™ power MOSFET. The EVM allows for simple evaluation of the DRV8305-Q1 with a wide array of test points, interfaces, and configurability.
  The EVM has onboard reverse battery protection, a regulated 3.3 V supply from the TPS7B6933-Q1 LDO, interface header for all control and feedback signals , and onboard XDS100v2 emulator. The EVM has individual DC bus and phase voltage sense as well as individual low-side current shunt sense for sensorless BLDC control algorithms. The drive stage is fully protected with short circuit, thermal, shoot-through, and undervoltage protection and is easily configurable via an SPI interface.
  The EVM is ideal for evaluation and rapidly developing with the DRV8305-Q1, with primary software support through MotorWare using the InstaSPIN-FOC sensorless control solution.
TI公司
  图3.DRV8305-Q1EVM外形图
  DRV8305-Q1EVM主要特性:
  4.4 V to 45 V Operating Supply Voltage Range
  Supports up to 25 A Continuous Output Current
  Provides Phase Voltage and Current Feedback ForSensorless BLDC Control Solutions
  Complete Brushless DC Control and Drive Stage
  Onboard XDS100v2 Emulator
  What’s Included
  DRV8305-Q1 Evaluation Board
  Micro-USB Cable
TI公司
图4.DRV8305-Q1EVM框图
TI公司
图5.DRV8305-Q1EVM电路图(1)
TI公司
图6.DRV8305-Q1EVM电路图(2):MCU DRV
TI公司
图7.DRV8305-Q1EVM电路图(3):电源
TI公司
图8.DRV8305-Q1EVM电路图(4):桥
DRV8305-Q1EVM材料清单:
TI公司
TI公司
TI公司
