xilinx公司SoC器件Zynq-7000开发方案介绍
嵌入式技术
1329人已加入
xilinx公司的Zynq®-7000是全编程SoC器件,是系统级集成电路,并具有硬件,软件和I/O可编程性,可设计更智能化的系统,大大地降低BOM成本,NRE成本,设计风险,同时加快产品面市.主要用在工业控制,马达驱动,测试和测量,嵌入式视角系统以及软件定义无线电和嵌入系统模块.本文介绍了Zynq®-7000系列特性,框图以及MicroZed开发电路板主要特性,框图,电路图和材料清单.
The Zynq®-7000 All Programmable SoCs are available in -3, -2, and -1 speed grades, with -3 having the highest performance. Zynq-7000 device DC and AC characteristics are specified in commercial, extended, and industrial temperature ranges. Except the operating temperature range or unless otherwise noted, all the DC and AC electrical parameters are the same for a particular speed grade (that is, the timing characteristics of a -1 speed grade industrial device are the same as for a -1 speed grade commercial device). However, only selected speed grades and/or devices are available in the commercial, extended, or industrial temperature range.
All supply voltage and junction temperature specifications are representative of worst-case conditions. The parameters included are common to popular designs and typical applications
soc
图1. Zynq-7000方框图
MicroZed™ is a low-cost development board based on the Xilinx Zynq®-7000 All Programmable SoC. Its unique design allows it to be used as both a stand-alone evaluation board for basic SoC experimentation, or combined with a carrier card as an embeddable system-on-module (SOM). MicroZed contains two I/O headers that provide connection to two I/O banks on the programmable logic (PL) side of the Zynq®-7000 AP SoC device. In stand-alone mode, these 100 PL I/O are inactive. When plugged into a carrier card, the I/O are accessible in a manner defined by the carrier card design.
MicroZedTM 是一款基于Xilinx Zynq®-7000 全可编程系统级芯片的低成本开发电路板。它的独特设计让其既可以被用作单独的基本SoC实验用的评估板,也可以与基板组合,用作嵌入式系统化模块(SOM)。 MicroZed 包括两个I/O 接头,在Zynq®-7000 AP SoC器件的可编程逻辑(PL) 端可以连接到两个I/O bank。在独立工作下,这100个P L I/O是闲置的。在插入基板后,这些I/O 可以按照基板设计所定义的方式访问。因此设计师可以从MicroZed独立工作开始,熟悉和了解这个平台;之后就可以很方便地通过增加一块现成的或用户设计的基板,来将其功能扩展为系统级模块。这种独立工作/SOM相结合的方法可以很快地将设计构思从概念转到投产,使MicroZed 成为基于SoC应用的理想平台。
套件包括:
MicroZed 电路板
Micro USB 电缆线
4 GB μSD 卡
Xilinx Vivado® WebPACK™ 许可证及逻辑分析仪软件(锁定使用器件)
快速入门文件
soc
图2. MicroZed开发电路板外形图
soc
图3. MicroZed开发电路板框图
MicroZed开发电路板主要特性:
SoC
XC7Z010-1CLG400C
存储器
»»1 GB of DDR3 SDRAM
»»128 Mb of QSPI Flash 存储器
»»Micro SD 卡接口
通信
»»10/100/1000 以太网
»»USB 2.0
»»USB-UART
用户I/O (通过两个板对板连接器)
»»100 个用户I/O (每个连接器50个)
»»最多可配置48对LVDS或100 个单端I/O
其它
»»2x6 Digilent Pmod® 兼容的接口,为用户I/O提供8 PS MIO 连接
»»Xilinx PC4 JTAG 配置端口
»»可以通过 Pmod 访问 PS JTAG 引脚
»»33.33 MHz 振荡器
»»用户 LED 和按键开关
目标应用
»»应用 Zynq®-7000 AP SoC 评估和原型设计
»»嵌入式系统化模块 (SOM) 应用
»»嵌入式视觉系统
»»测试 & 测量
»»电机控制
»»软件定义无线电
soc
图4. MicroZed开发电路板电路图(1)
soc
图5. MicroZed开发电路板电路图(2)
soc
图6. MicroZed开发电路板电路图(3)
soc
图7. MicroZed开发电路板电路图(4)
soc
图8. MicroZed开发电路板电路图(5)
soc
图9. MicroZed开发电路板电路图(6)
soc
图10. MicroZed开发电路板电路图(7)
soc
图11. MicroZed开发电路板电路图(8)
MicroZed开发电路板材料清单:
soc
soc
