No matter if you’re a student, a designer or an engineer, at some point you’ve stumbled upon the need to make an idea real. The Zortrax M200 allows you to do just that. You can create high-precision durable models of any shapes and colors. And since it’s inexpensive, you can print a model, after model, after model, seeing your project in reality even during design.
Here are the specifications:
•Slick, aluminum design that just works. It really ties your office space together. It just fits the room
• Solid, stable aluminum printer frame, guaranteeing high-precision printing
• Printer head specially designed for ABS, PC-ABS and Nylon material – Innovative, state-of-the-art high-precision material dosing mechanism
• Just unbox it! Plug & Print!
• Gantry system is based on idea comes from MIT:
The slicing engine included in the Zortrax Suite is a ready solution designed and programmed by Gadgets 3D with no 3rd party software included! Everything, from the engine to a handsome GUI was created by the team from scratch.
Why is the Zortrax Suite awesome?
•Built-in slicing engine fixes the majority of possible errors that can occur in .stl models and does it automatically during the slicing process!
•Slices really big and complex models in a very short time
•You can set the layer thickness to a variety of options: 0.1mm, 0.14mm, 0.2mm, 0.3mm
•The engine created focuses on maintaining the geometry of your model as close as possible to your project
•Three different printing speed modes
•Automatic support generation, so you can print those really complicated models
•No USB connection is required – just use the included SD card reader!
•Supports Windows XP, Windows Vista, Windows 7 and Windows 8, including virtual machines!
自动翻译仅供参考
Gadgets 3D 推出Zortrax 新型桌面3D打印机和设计组件
不管你是学生、设计师还是工程师,在某个时候你都会无意中发现一个想法的真实性。ZORTRAX M200可以让你做到这一点。您可以创建任何形状和颜色的高精度耐用模型。而且因为它便宜,你可以打印模型,模型后,模型后,看到你的项目在现实中,甚至在设计过程中。
这里有规格:
•油滑,铝的设计,只是工作。这真的绑您的办公空间在一起。它只是适合房间
•牢固,稳定的铝框架打印机,确保高精度打印
•打印机头专为ABS,PC,ABS和尼龙材料 - 创新,高精度计量的材料机理国家的最先进的
•刚拆箱吧!即插即打印!
•基于想法龙门系统来自麻省理工学院:
列入Zortrax套房切片引擎是一个现成的解决方案,并通过小工具3D编程包括任何第三方软件!一切,从发动机到一个英俊的图形用户界面是由小组从头开始创建。
为什么Zortrax套房真棒?
•内置切片引擎修复大部分可能发生的可能存在的错误.STL模型和在切片过程自动完成!
•片真正的大和复杂的模型在极短的时间
•您可以设置层厚度有多种选择:0.1mm时,0.14毫米,0.2毫米,0.3毫米
•创建的引擎专注于保持模型的几何形状尽可能接近到项目
•三种不同的打印速度模式
•自动生成的支持,这样你就可以打印那些真正复杂的模型
•无需USB连接 - 只需使用附带的SD读卡器!
•支持Windows XP,Windows Vista中,Windows 7和Windows 8,包括虚拟机!
