矩阵键盘的verilog代码分享
可编程逻辑
1334人已加入
define  SCAN
module  key_scan(
clk    ,
rst_n  ,
key_col, //键盘列输入
key_row, //键盘行输出
key_num, //指示哪一个按键按下,用0~15指示
key_vld  //按下有效指示信号,其为1表示按下一次。
parameter      KEY_W    =   4 ;
parameter      COL      =   0 ;
parameter      ROW      =   1 ;
parameter      DLY      =   2 ;
parameter      FIN      =   3 ;
parameter      COL_CNT  =   16;
parameter      TIME_20MS=   1000000;
//输入信号定义
input               clk    ;
input               rst_n  ;
input  [3:0]        key_col;
//输出信号定义
output              key_vld;
output[3:0]         key_num;
output[KEY_W-1:0]   key_row;
//输出信号reg定义
reg   [3:0]         key_num;
reg   [KEY_W-1:0]   key_row;
reg                 key_vld;
reg   [ 3:0]        key_col_ff0   ;
reg   [ 3:0]        key_col_ff1   ;
reg   [ 1:0]        key_col_get   ;
reg                 shake_flag    ;
reg                 shake_flag_ff0;
reg   [ 3:0]        state_c       ;
reg   [19:0]        shake_cnt     ;
reg   [ 3:0]        state_n       ;
reg   [ 1:0]        row_index     ;
reg   [15:0]        row_cnt       ;
reg   [ 2:0]        x             ;
always  @(posedge clk or negedge rst_n)begin
if(rst_n==1'b0)begin
key_col_ff0 <= 4'b1111;
key_col_ff1 <= 4'b1111;
end
else begin
key_col_ff0 <= key_col    ;
key_col_ff1 <= key_col_ff0;
end
end
shake_cnt <= 0;
end
else if(add_shake_cnt)begin
if(end_shake_cnt)
shake_cnt <= 0;
else
shake_cnt <= shake_cnt + 1;
end
else begin
shake_cnt <= 0;
end
end
assign  add_shake_cnt = key_col_ff1!=4'hf && shake_flag==0;
assign  end_shake_cnt = add_shake_cnt && shake_cnt==TIME_20MS-1;
shake_flag <= 0;
end
else if(end_shake_cnt) begin
shake_flag <= 1'b1;
end
else if(key_col_ff1==4'hf) begin
shake_flag <= 1'b0;
end
end
`ifdef SCAN
state_c <= COL;
end
else begin
state_c <= state_n;
end
end
always  @(*)begin
case(state_c)
COL: begin
if(col2row_start)begin
state_n = ROW;
end
else begin
state_n = state_c;
end
end
ROW: begin
if(row2dly_start)begin
state_n = DLY;
end
else begin
state_n = state_c;
end
end
DLY :  begin
if(dly2fin_start)begin
state_n = FIN;
end
else begin
state_n = state_c;
end
end
FIN: begin
if(fin2col_start)begin
state_n = COL;
end
else begin
state_n = state_c;
end
end
default: state_n = COL;
endcase
end
assign  col2row_start = state_c==COL && end_shake_cnt;
assign  row2dly_start = state_c==ROW && end_row_index;
assign  dly2fin_start = state_c==DLY && end_row_index;
assign  fin2col_start = state_c==FIN && key_col_ff1==4'hf;
key_row <= 4'b0;
end
else if(state_c==ROW)begin
key_row <= ~(1'b1 << row_index);
end
else begin
key_row <= 4'b0;
end
end
row_cnt <= 0;
end
else if(add_row_cnt) begin
if(end_row_cnt)
row_cnt <= 0;
else
row_cnt <= row_cnt + 1;
end
end
assign add_row_cnt = state_c==ROW || state_c==DLY;
assign end_row_cnt = add_row_cnt && row_cnt==COL_CNT-1;
row_index <= 0;
end
else if(add_row_index) begin
if(end_row_index)
row_index <= 0;
else
row_index <= row_index + 1;
end
end
assign add_row_index = end_row_cnt;
assign end_row_index = add_row_index && row_index==x-1;
always  @(*)begin
if(state_c==ROW)
x = 4;
else
x = 1;
end
key_col_get <= 0;
end
else if(col2row_start) begin
if(key_col_ff1==4'b1110)
key_col_get <= 0;
else if(key_col_ff1==4'b1101)
key_col_get <= 1;
else if(key_col_ff1==4'b1011)
key_col_get <= 2;
else
key_col_get <= 3;
end
end
key_num <= 0;
end
else if(state_c==ROW && end_row_cnt)begin
key_num <= {row_index,key_col_get};
end
else begin
key_num <= 0;
end
end
key_vld <= 1'b0;
end
else if(state_c==ROW && end_row_cnt && key_col_ff1[key_col_get]==1'b0)begin
key_vld <= 1'b1;
end
else begin
key_vld <= 1'b0;
end
end
`else
key_vld <= 0;
end
else begin
key_vld <= end_shake_cnt;
end
end
always  @(*)begin
key_num = 0;
end
`endif
endmodule
